After Battery died nothing but tranny issues
Old 08-01-16, 12:14 AM
sulten
sulten's Avatar
Default After Battery died nothing but tranny issues
well as the title says my battery died on me so I had it replaced, then noticed the tranny wouldn't shift correctly or down shift. I did the shift lock and it doesn't seem to work. starts off slow in gears takes awhile to shift but does but doesn't go higher then 5th. All over a battery. any ides. 07 is250
Old 08-01-16, 05:16 AM
bbaugher47
bbaugher47's Avatar
Sounds like the ecu needs to relearn your driving habits. And your windows are going to be jacked up as well.
Old 08-01-16, 11:43 AM
VTsuckah
VTsuckah's Avatar
My 350 had been sitting in the garage for weeks with a dead battery. I replaced it last weekend and transmission shifting has been a bit harsh, but this is common as the ECU has to "re-learn" your driving habits as bbaugher47 stated. However, I never had any issue with the trans shifting to 6th gear.
Old 08-01-16, 12:26 PM
flowrider
flowrider's Avatar
Received 1,815 Likes on 1,281 Posts
And no CEL?
Lou
Old 08-01-16, 01:12 PM
Bichon
Super Moderator
Bichon's Avatar
I'm not sure if this is related to your issue, but the car is programmed to avoid 6th gear until the car has warmed up.
Old 08-01-16, 01:25 PM
flowrider
flowrider's Avatar
^^^^He's in Arizona - I doubt that's an issue, especially at this time of year!
Lou
Old 08-01-16, 04:35 PM
355F1
355F1's Avatar
Lou
HAH! True story!!!
I live in AZ, too!
Old 08-01-16, 05:02 PM
lysis250
lysis250's Avatar
I live in CA so it's pretty hot here too but the car also won't shift passed 5th until it reaches its running temperature. The fact that it's hot just helps it get there faster.
Old 08-02-16, 03:36 AM
sulten
sulten's Avatar
How long does the ECU take? I work 5 miles from work so I don't drive much just to work then home. I have been driving it but 1 day down and still the same issue.
atticusgre
12-31-18 11:46 AM
hchen
LX - 3rd Gen (2008-2021)
03-09-18 12:16 AM
P128sniper
03-25-14 09:35 PM
DzaztrBUSE
04-05-13 06:45 AM
mwbuck
RX - 1st Gen (1999-2003)
08-01-06 09:56 AM
Quick Reply: After Battery died nothing but tranny issues
