Just Purchased 2006 IS350 with 138,000 Miles. What Oil Would you Suggest?
Old 02-27-14, 06:18 PM
kedmunds
kedmunds's Avatar
Default Just Purchased 2006 IS350 with 138,000 Miles. What Oil Would you Suggest?
Hello Everyone,
I just purchased a great looking and great running 2006 IS350 with 138,000 miles on it. I am curious what any of you would suggest as far as the Oil I should use going forward. I am not sure what was used previously, so I would be starting the Oil changes at 138,000 miles.
I am curious about the type of Oil you would suggest and the weight like 5W20 or 5W30? Many of the Forums suggest Castrol Edge Synthetic. What are your thoughts?
Any suggestions would be Greatly Appreciated.
Thank You,
Kirk
Old 02-27-14, 06:23 PM
JdSwiper
JdSwiper's Avatar
That's simple. Amsoil!!! or if you want something that you can find easy, locally.... Mobile 1, those are the best two, IMO !!!!
Old 02-27-14, 06:31 PM
pheonix72
pheonix72's Avatar
I stick with manufacturer's recommendation of 5w30. I use whatever synthetic on sale or easily available at the local auto parts stores.
Old 02-27-14, 06:44 PM
TheVille
TheVille's Avatar
Get royal purple. Best oil you can buy
Old 02-27-14, 07:10 PM
kedmunds
kedmunds's Avatar
What Weight Oil would you suggest for a car with 138,000 miles?
Old 02-27-14, 07:12 PM
pheonix72
pheonix72's Avatar
Did u read my post ?
Old 02-27-14, 07:22 PM
Serifiyah
Serifiyah's Avatar
I use mobil 1 5w20, since there was a TSB that Lexus recommends 5W20 now.
Old 02-27-14, 07:43 PM
Raybean
Raybean's Avatar
Nothing wrong with mobile 1. I would just use 5w-30.
Old 02-27-14, 07:53 PM
Nsteezyy
Nsteezyy's Avatar
Mobile 1 Full synthetic 5w-30 is what I run!
Old 02-27-14, 09:48 PM
Lexustom
Lexustom's Avatar
That is exactly what I run in my '06 IS 350. I have since the first time the factory oil got changed.
Old 02-27-14, 10:06 PM
jdmSW20
jdmSW20's Avatar
you should already know this thread is going to be all opinions on what oil people think is best. there really is no clear cut "best". its all subjective. whatever works for you run with it.
me personally i run eneos 0w-20 synthetic. ive run it in all my last 5 cars(tried all different weights as well) with no issues and all but 1 had over 150k miles. so find what works for you and go with that
Old 02-27-14, 10:15 PM
pheonix72
pheonix72's Avatar
[QUOTE=jdmSW20;8405404]you should already know this thread is going to be all opinions on what oil people think is best. there really is no clear cut "best". its all subjective.that[\QUOTE]
And just like #%@hole, everyone has their own opinions on oil. Use whatever is most convenient to get. Go with manufacturer's recommended weight. Change your oil on mileage and/or time; i change my every 5k. I clocked over a millions miles (with several cars went over 200k miles) and never have any problem (YET
Old 02-27-14, 10:16 PM
sw2oboi
sw2oboi's Avatar
Regular Castrol Gtx (white) is good enough. If you plan to run more then 5000miles in a 6 month period then I suggest synthetic like Castrol syntec (black container). Just about any synthetic should last well over 5,000 miles for this car. Start with 5-30 and go from there if needed. check oil every 1000 miles and monitor oil consumption.
FYI, you don't need to go crazy with high end oil and changing the oil sooner then manufacture recommendations because this engine wears very little and is gentle on the oil.
Old 02-27-14, 10:36 PM
smokyis350
smokyis350's Avatar
Any brand synthetic oil will be fine. They are tested and regulated by the government to meet regulations just like gasoline. For the oil viscosity, I would choose either 5w-20 or 5w-30.
Old 02-28-14, 07:12 AM
tomiv9
tomiv9's Avatar
what is the difference between 5w20 and 5w30? why do some people think one is better then the other?
Quick Reply: Just Purchased 2006 IS350 with 138,000 Miles. What Oil Would you Suggest?
