2009 IS250AWD Rack Pinion Removal Instructions
Hello, if someone would be kind enough to print me the steps for
2009 IS250AWD Steering Rack Pinion Removal ...
Also can i get this from a local parts store?
I have, disconnected both ends of the rack and pinion, removed the steering wheel shaft ftom the little motor, removed both wheels, removed all the wires and connections, both the main bolts that hold it in place, then....removed the little motor to make the rack and pinion smaller around, took the nuts off the engine mounts and jacked the engine up and now it hits the sway bar...i assume it must be removed too??????
any help would be appreciated...............
mack
mack
Here are the components listed under steering. What exactly are you wanting?
Steering Components
jeff
Air Bag(s) Arming and Disarming
Front Steering Knuckle
Power Steering
Power Steering Motor
Relays and Modules - Steering
Seat Belt Arming and Disarming
Steering Angle Sensor
Steering Column
Steering Column Control Module
Steering Column Cover
Steering Column Lock
Steering Column, Coupling Shield
Steering Column, Upper Bracket
Steering Control Module
Steering Gear
Steering Mounted Controls Assembly
Steering Mounted Controls Transmitter
Steering Rack Gear
Steering Shaft
Steering Shaft Coupler
Steering Shaft Coupler, Coupling Shield
Steering Wheel
Steering Wheel, Rear Cover
Telescoping Wheel Switch
Tie Rod Boot
Tie Rod End
Tilt Wheel Motor
Tilt Wheel Switch
Power Steering
Steering Column
Steering Gear
Steering Rack Gear
Steering Shaft
Steering Wheel
Tie Rod Boot
Tie Rod End
Tilt Wheel Motor
Tilt Wheel Switch
WoW...we finally got it out with unbolting the sway bar on each side and folding it up, jacking the motor up as high as possible from the oil pan with the mount nuts removed.
It was a *****! Especially with no instruction "anywhere" on alldata or google.
Had to do it the old fashined way...look feel remove.
thanks
mack
thanks
mack
emiasunki
03-07-18 11:49 AM
