Which spoiler should I get?
Old 01-02-14, 06:26 PM
joshua28
joshua28's Avatar
Default Which spoiler should I get?
I'm looking for a trunk spoiler on ebay and I've come across two different types. There's one style like this: http://www.ebay.com/itm/321284248595...84.m1423.l2649
and another: http://www.ebay.com/itm/231126690937...84.m1423.l2649
...they are both from oem.thing. Which one looks better? Also what's the difference between ABS and FRP? TIA.
Old 01-02-14, 07:01 PM
lysis250
lysis250's Avatar
IMO the second one is better. The first looks identical to the FSport spoiler.
Old 01-02-14, 07:27 PM
jdmSW20
jdmSW20's Avatar
ABS is platic, FRP is somewhere in the middle of fiberglass and urethane
Old 01-02-14, 07:31 PM
alexs350
alexs350's Avatar
I like the first one more than the second.
Old 01-02-14, 07:34 PM
iRock
iRock's Avatar
The one you like more?
Old 01-02-14, 08:02 PM
DFig619
DFig619's Avatar
Someone correct me if I'm wrong but I believe
FRP - fiberglass reinforced plastic
Vertex uses a similar method to their kits that's why you can scrape or hit and it won't crack
Old 01-02-14, 09:28 PM
teekaytk
teekaytk's Avatar
none of them do 4P7 "mystic gold metallic" , the color of my car
Old 01-02-14, 09:58 PM
rookieIS
rookieIS's Avatar
Get whichever one you like, doesn't matter what others say
joshua28
joshua28's Avatar
I went with the second one. I hope it matches the color of my car because the seller said white colors (starfire or glacier frost) and red are harder to match to oem. I wouldn't mind if it's just a very slight difference.
Old 01-02-14, 11:42 PM
ms2619
ms2619's Avatar
Neither... Wald all day
Old 01-03-14, 07:54 AM
kyoso23
kyoso23's Avatar
I bought an OEM Thing roof spoiler in SFP and it turned yellow in one summer. I just had it repainted.
Old 01-03-14, 07:30 PM
joshua28
joshua28's Avatar
I'm going to wait to see how well the color matches first then decide whether or not to get the roof spoiler from them...
Old 01-03-14, 07:47 PM
smokyis350
smokyis350's Avatar
You should check out the Wald one. It probably looks the best, IMO.
Old 01-03-14, 10:02 PM
Initial G
Initial G's Avatar
I'd go with the first one if I had to choose between the two.
The second one looks too much OEM.
If you are ever in the mkt for another spoiler, you should check out Ings+1 or wald.
Good luck with the paint, hope it matches.
Old 01-03-14, 11:38 PM
kyoso23
kyoso23's Avatar
The roof spoiler itself looks good, just didn't match well and then the clear coat yellowed.
Quick Reply: Which spoiler should I get?
