Help from IS owners with 19s
Old 12-26-13, 04:00 AM
dannyboy26
dannyboy26's Avatar
Default Help from IS owners with 19s
Hi everyone,
So I am looking into getting some STR 607 or 610s 19x8.5 F with +30 offset and 19x10.5 R with +35 offset my question is will this work on my RWD Is250 and will I need any fender rolling, I have been doing a lot of research but would really like some input please from owners with aggressive wheels, I am looking for just flush and also for a H&R or Megan racing spring 1.5" drop
Old 12-26-13, 10:39 AM
g2bme
g2bme's Avatar
you don't need fender rolling. There's some people on here that say they rub, some that say they don't. Depending on the tire size you go with, brand of tires. I have Pirelli's on mine and did the recommended settings to stay within specs but every hard turn, Sharp U turn's or downhill sharp turns (going about 5mph or less) i hear a rub. It's the fender liner, not the tabs. I've been wanting to use a heatgun and just do the fix but I'm too lazy to take off my tire and spend at least an hour or so getting one side done.
Old 12-26-13, 11:34 AM
Sffd103
Fire Slayer
Sffd103's Avatar
you should be fine with that. You going to go with a 235/35/19 and 265/30/19 tires?
Old 12-26-13, 12:39 PM
whitebeast
whitebeast's Avatar
You're fine on springs only.
Old 12-26-13, 05:14 PM
Is350Josh
10th Gear
Is350Josh's Avatar
Depends on the tire size.
Old 12-26-13, 07:42 PM
jdmSW20
jdmSW20's Avatar
its going to be dependent on your tire specs and low you are going to end up. because having a 19x8.5 a 225/35 is going to be square and my by chance gravity pull your front fenders without a roll at that offset. i have a 265/30 on a 19x10 +32 rear and im positive it'll rub had i not had my rears rolled.
but then again i have more than a 1' drop too
Old 12-26-13, 11:38 PM
dannyboy26
dannyboy26's Avatar
yeah for the front yes, for the back I was actually thinking 255's to avoid rubbing but if it doesnt rub with 265 then will go with that
Old 12-26-13, 11:41 PM
dannyboy26
dannyboy26's Avatar
The fender liners?? sorry if I sound dumb but where in the F or R
Old 12-26-13, 11:43 PM
dannyboy26
dannyboy26's Avatar
well the springs im getting are by Megan Racing saying it will drop it 1.5 all around, so you are saying that may need a roll... but with the front if I leave it at 225's I should be good right?
Old 12-26-13, 11:50 PM
jdmSW20
jdmSW20's Avatar
well granted i have far more than a 1.5 drop, my front fenders werent rolled with my 19x8.5 +27 effective offset my fenders did get some gravity pull. so i would honestly suggest a fender roll with those spec wheels.
because say one day you get the urge to go lower and swap to coilovers, you are still good to go. versus you will have to do it eventually anyway
Old 12-26-13, 11:57 PM
dannyboy26
dannyboy26's Avatar
Thanks for the input, will start looking into getting my fenders rolled in the rear, for th front what all did you do since you didnt need a roll did you have to work on the tabs?
Old 12-27-13, 12:06 AM
jdmSW20
jdmSW20's Avatar
yes i got rid of the bumper tabs. but all this is considering my car is slammed. if you dont plan on going real low then some of these wont apply to you. but i would do a fender roll at minimum. but thats just me
Old 12-27-13, 11:55 AM
static250
static250's Avatar
Definately get the rears rolled
Old 12-27-13, 01:23 PM
topspeed55
topspeed55's Avatar
The rears won't be just flush with the fenders, it will stick out past the fenders a bit and would probably require rolling if you are dropped too low.
I have 19x9.5 and 40mm offset in the rear, this setup doesn't rub and just sit flush enough without rubbing. I'm even running 275 rears and dropped one inch.
Old 12-27-13, 03:30 PM
jgr7
jgr7's Avatar
I'm running 19x10 +38 with 275/30 19 ZR michelin Pilot Super Sports dropped on BC/BR coilovers and if I go to low they will rub. I put some negative camber in and raised it a little and no problems now. The fronts are 19x8.5 + 32 235/35 ZRs and they will also rub if I go to low, I put some neg camber into the front and raised it a little more and only have a little inner fender liner rub now that a heat gun will fix.
Quick Reply: Help from IS owners with 19s
