Intermittent wipers dont work
Old 12-07-13, 09:49 PM
markjustus
markjustus's Avatar
Default Intermittent wipers dont work
Does anyone else have this problem? my windshield wipers work on every setting besides the intermittent mode, any help is much appreciated with this freezing california weather.
Old 12-08-13, 12:20 PM
Gville350
Gville350's Avatar
Perhaps a short in the wiper switch stock itself; perhaps a new wiper stock could fix it. I had to do this once in a Honda Civic I had; easy fix really.
Old 12-09-13, 08:22 AM
markjustus
markjustus's Avatar
thanks for the input, ill probably end up swapping that out
Old 12-09-13, 01:00 PM
panda08
panda08's Avatar
good luck with that. post pics for a diy maybe?
Old 12-09-13, 05:29 PM
tex2670
tex2670's Avatar
Any chance you have the Luxury or Sport Package, and have rain-sensing wipers? If so, the Auto position replaces intermittent mode.
Old 12-10-13, 02:52 AM
Stevoe88
Stevoe88's Avatar
There recently was a recall for this, check with your local dealership to see if they will fix this for you out of warranty.
Old 12-10-13, 04:15 AM
Bichon
Super Moderator
Bichon's Avatar
The recall was for a problem with the nuts that hold on the wiper arms, not for a problem with the intermittent wiper setting.
Old 12-27-13, 02:32 PM
Kimosabbe
Kimosabbe's Avatar
Same problem. I removed the switch, took it apart and cleaned it up (the dilectic grease was black on the contacts), but intermittent still doesn't work.
I was hoping someone had a fix like the one for the clock (which worked great for me). With the clock there were certain solder spots that needed to be heated up (but not resoldered).
I'll post again if I can figure this out without purchasing a new or used one.
Old 02-23-14, 06:06 AM
manuk
manuk's Avatar
Default Quick temp repair for intermittent wiper issue, sensor down.
Behind the rear view mirror, you will find a black box attached the the front windscreen, at the bottom the this box you will see a release clip that can be removed with a small flat head screwdriver, push it into holes on the side and pull down to release, this will allow the rain sensor to drop from the windscreen, unplug the auto wiper plug from the socket, replace everything in reverse order and you should be done. everything will operate as should and you will have intermittent wipers on the auto position using the stalk, replace rain sensor for full fix.
trevans77 (12-22-23)
UWhite504F
10-22-19 06:54 AM
lchang
10-10-16 06:04 AM
SerasLibre
04-04-14 05:28 AM
pianowoman
RX - 1st Gen (1999-2003)
11-26-09 10:30 PM
Todd
02-18-06 04:08 AM
Quick Reply: Intermittent wipers dont work
