Time for the first oil change...
Old 08-28-13, 10:06 AM
Vane824
Vane824's Avatar
Default Time for the first oil change...
Hi guys,
Quick question.... i bought my used IS 2008 back in May. I've finally came up to the first 3K of me driving the car. So i assume its about that time to change the oil.
What type oil change do you advise i should get? Regular, synthetic or blended? i do not kow what the previous oil used was or when that was. Should i take it to the dealer for the oil change or can it go anywhere?
Also i'd like to point out that after just one month of having the car i had to take it in because the pistons had the carbon buildup so they were replaced. I was advised by CL to get the fuel injection bottle and pour it in as soon as i got it back from the dealer. Should i do this again after the oil change? I've only been pumping premium gas from Chevron since then thanks to the top tier gas thread i read on here.
Thanks!!
Old 08-28-13, 10:09 AM
HAiS250
HAiS250's Avatar
its 5k and your cluster should let you know when its time for an oil change
Old 08-28-13, 10:13 AM
Initial G
Initial G's Avatar
^+1
Try synthetic oil for a change.
Old 08-28-13, 10:46 AM
kickin8
2IS/2RX/4RX
kickin8's Avatar
+1 for 5K ...
Old 08-28-13, 11:07 AM
zmcgovern4
Auto Detailing Master
zmcgovern4's Avatar
+1 for synthetic... I just change mine every 12 months because I don't even drive 10k a year.
Old 08-28-13, 12:26 PM
DKnight350
DKnight350's Avatar
Oil changes are all about peace of mind. Any name brand oil is fine (dyno/blend/synthetic). I use synthetic and change it every 10k (as recomended by my local Toyota dealership - Mobile 1 0w-20 for $55 out the door).
On this forum, everyone has an opinion on this. Do your research and decide what makes you sleep better.
Old 08-28-13, 12:42 PM
edgeucated
edgeucated's Avatar
depending on which type of oil you use, the oil intervals are roughly 10k miles for synthetic and 5k miles for dino(regular?) oil or once every 12 months. HOWEVER, oil filters are rated for only 5k.
So if you do 10k oil change, you still have to change the filter at 5k.
3k oil changes are a thing of the past.
Old 08-28-13, 12:48 PM
Vane824
Vane824's Avatar
thanks every1! i will give it 2K more before i get an oil change then so i can get synthetic and wont have to worry about it for another 10K!
What does +1 mean?
Old 08-28-13, 02:13 PM
UniSlayEX
UniSlayEX's Avatar
What does +1 mean?
It's like "add me to that list" or "add another vote for it." "It" being whatever is being discussed.
I thought we had figured out that there is a synthetic filter from the FJ we could use.
To answer your question OP, I'm still on the factory motor oil. but you could go to synthetic no problem, just keep in mind you cant go back...
Old 08-28-13, 07:02 PM
MGB
MGB's Avatar
What does +1 mean?
Hey just a thought but how sure are you that the oil was changed when you bought the car. When I buy use and I can 't be 100% sure the oil is fresh, I change it soon as I get home ore to the nearest lube joint! Just saying.
Old 08-28-13, 08:18 PM
edgeucated
edgeucated's Avatar
that is a myth that you can't switch back and forth between dino and synthetic oil. You can interchange them at different periods without any repercussion to your engine.
Could you post a link to this synthetic filter? I have been using the Lexus recommended filter and would be very interested in a specialize filter.
Old 08-29-13, 05:01 AM
bob4256
bob4256's Avatar
Same here ^^
Just recently changed my oil + filter at around 7K miles and my filter looked fine
Old 08-29-13, 06:36 AM
magnuscat
magnuscat's Avatar
That's true you can change back and forth in oil changes. However synthetic has smaller particles than dino oil. If you have a high mileage engine with slight gasket degradation synthetic oil will find places to seep that have never seeped before. Just a word of caution if you notice this, it isn't because the synthetic caused new seepage, it just finds microscopic gaps more than dino oil will.
Old 08-29-13, 04:45 PM
UniSlayEX
UniSlayEX's Avatar
Didn't know you could interchange oils. You learn something new everday on CL .
I'm still in the office and the sythetic filter info is back at home. I'll get it to you guys ASAP...
***UPDATE***
Originally Posted by JohnLX300
Anyone use the PTR43-00079 oil filter in their IS? Just wondering if any one is using these filters?
Originally Posted by Gville350
Not on any 2ISs that I know of :
High Performance Oil Filter (PTR43-00079)
This part fits the following vehicles:
Toyota: 4Runner 2010 - 2012
Toyota: FJ Cruiser 2010 - 2012
Originally Posted by quick123
I have one in my car now...first time using one, figured it couldn't hurt, plus I got it for free from a friend
I don't think there is any real need to use the TRD filter, as Toyota produces probably the highest quality OEM filter out there...
Here's "proof" it can be done. But when I did my research I came up with a different part numbers and that it is actually a filter cartridge but it fit for the IS-F. Maybe it can fit and we just have yet to confirm it. I'll create a thread on the TRD Oil Filters. Maybe quick123 can chime in on what he did... Sorry edgeucated and bob4256, thought it was a done deal.
Thread: TRD Oil Filter for IS
https://www.clublexus.com/forums/is-...er-for-is.html
pam1980
Hybrid Technology
01-08-17 01:58 PM
FLYCT
10-22-15 11:52 AM
tieu
Canada
12
10-16-08 12:09 AM
Taka
SC- 1st Gen (1992-2000)
12-12-01 01:09 AM
Quick Reply: Time for the first oil change...
