Need help, IS350 won't start
Old 08-14-13, 06:49 AM
RTIS250
Yes. I drove the LFA.
RTIS250's Avatar
Originally Posted by nielsio
It can, if the sensors are not getting a read on the oxygen, the ecu does not know what to do with it. Best to replace when you're at that milage.
The car starts in open loop, meaning the ECU is not looking at the AF sensor readings. I highly doubt it is a bad AF sensor.
As others have stated, i would look into the battery/charging system first.
Old 08-19-13, 09:53 AM
Pennies350
Pennies350's Avatar
Ended up taking it to the dealer. Up to $4k so far. What they found was a 2 bad cam gear and a cam. Now this is why I didn't want to take it there. Pure rapage
Old 08-25-13, 07:49 PM
Chaoticjew
Chaoticjew's Avatar
Damn $4,000!!! Sorry to hear that. What did they say caused the damage?
Old 08-26-13, 06:10 AM
Pennies350
Pennies350's Avatar
they dont know
Old 09-04-13, 06:30 AM
Pennies350
Pennies350's Avatar
i think im going to be calling my dealer once they open. new recall and its the exact issue they found where the bolts were loose causing the 2 cam shaft and camshaft to seize. the car was making the camshaft noise at start up for years and the dealer kept saying it was normal. i know that ive read on here that it happens to a lot of you so i would recommend taking it in asap.
The other recall involves approximately 102,000 model 2006 through 2011 Lexus IS 350, IS 350C, and GS 350 vehicles.
Bolts that hold the variable valve timing control device could come lose, causing the cars to stop.
Toyota says a possible early warning of the problem is abnormal noise just after start-up.
Owners of vehicles subject to these recalls will be notified soon.
url]
Old 09-04-13, 11:34 AM
nosurprise
nosurprise's Avatar
Interesting ... what noise did you look for exactly? I think my car sound pretty normal at start up -- I still have 1000 miles to go before the next oil change, not sure if I should go sooner to get the recall done.
Old 09-05-13, 07:20 AM
B16da9
B16da9's Avatar
$4,000.00??? at the price I would have put a newer lower mileage engine in to the car instead of fixing the old one.
Old 09-10-13, 04:35 AM
Pennies350
Pennies350's Avatar
here's the chatter.
and
it only happens when the car's been sitting for a while as well. this is a common problem that lexus has known about and only now is starting to do something about it.
i called to talked to my dealer and they were like wtf, we're not refunding you anything. i chatted some more with customer service and they're investigating into what the parts the dealer replaced. in this case, they replaced the loose bolt, and 2 cam gears which are the vvti's. all 3 are being recalled as it can cause the ecu to shut the engine down which happened in my case. i just hope that i can get reimburse for it
Old 09-10-13, 07:17 AM
darrenk
darrenk's Avatar
I'm not sure if this is helpful but I too had the same start up rattle but it wasn't in a lexus, it was in my 2008 TRD Aurion (supercharged 3.5 litre 6 cylinder available as a limited edition in Australia).
When I brought the car into Toyota for diagnosis (outside of warranty) in 2012, they immediately knew the problem and replaced the cam gears and hydraulic tensioners (from memory). As such, I think this is a systemic problem for this family of engines and I can only hope they've sorted this out on my 2012 IS350 F Sport
Old 09-10-13, 07:25 AM
4TehNguyen
4TehNguyen's Avatar
the recall doesnt affect 2012-13 models
Old 09-10-13, 07:43 AM
darrenk
darrenk's Avatar
I understand that but I wonder if that's because they fixed the problem at manufacture point or if there has been no complaints from the later batch 'yet'
Old 10-29-13, 02:28 PM
Pennies350
Pennies350's Avatar
Update: just got a call from Lexus HQ today. They will be reimbursing me for everything as it was due to the failure of the same parts from the recall.
Old 10-29-13, 04:36 PM
mike33
mike33's Avatar
Thats great to hear!
rodrigues
06-21-22 11:44 AM
954
07-12-12 08:39 AM
dtan1691
Performance
02-15-11 06:46 PM
bzubke1
Performance & Maintenance
10-11-08 07:19 AM
flossn
02-12-05 05:21 PM
Quick Reply: Need help, IS350 won't start
