Help!!! Check AWD
Old 06-30-13, 10:58 AM
Scless
Scless's Avatar
Default Help!!! Check AWD
I just installed my Work VS XX 18 x 9.5 all around with 15mm spacers. As I drove away from my shop Check AWD came on my dash along with brake light and trac control. I pulled the code for C1403 Malfunction Right rear wheel speed sensor. I checked the PID with my scan tool and only wheel speed sensor working is my left rear?! Anyone have this problem?? Its a 2012 IS350 if that helps.
EDIT
All 4 tires 225 40 18
Old 06-30-13, 11:31 AM
laobo979
laobo979's Avatar
Those tire size shouldn't throw off the speed sensor. Could the shop had done something? I say try either putting the stock back in to see if the code are gone. Or try to reset the code to see if it come back rite away.
Old 06-30-13, 12:26 PM
Scless
Scless's Avatar
I did the work. I haven't programmed my TPMS yet and the TPMS light is on but it shouldn't turn on the CHECK AWD and Brake and traction control.... Right?
Old 06-30-13, 12:59 PM
Chuy250
Chuy250's Avatar
Post
Disconnect your battery for a few minutes, that should restart the computer. If the light doesn't reappear then your good because nothing really is wrong, but if it appears once again then there is something wrong. I would put the stock ones back to see if the new wheels are causing the problem.
Old 07-01-13, 06:05 AM
blackgpgt
blackgpgt's Avatar
Are the tires sidewall the same all the way around?
Old 07-01-13, 07:18 AM
laobo979
laobo979's Avatar
No it shouldn't are the tires new and same brand? Cause if there used tires with good amount of ware that might be an issue. With the awd gotta be even thread ware.
Old 07-01-13, 07:30 AM
Scless
Scless's Avatar
Tires are brand new and same tread. Not sure about the profile I'll check but when I bought them from the warehouse should be the same. Didn't think anyone would reply. Thanks guys much apprectiated
Old 04-13-14, 02:22 PM
amadito
amadito's Avatar
Default amadito
EDIT
Hi I have the same code c1403 have any solution on this thanks
Old 04-13-14, 02:26 PM
amadito
amadito's Avatar
Help!!! Check AWD code for C1403 Malfunction Right rear wheel speed sensor
JDUB509
03-01-16 05:29 PM
bklynchris
11-29-15 04:13 PM
Nexgen76
ES - 5th Gen (2007-2012)
11-05-15 02:35 PM
dbs600
01-23-15 11:57 AM
JOHNBRAY11
RX - 1st Gen (1999-2003)
05-20-07 10:59 AM
Quick Reply: Help!!! Check AWD
