Diy Serpentine belt change 4GR-FE?
Old 06-09-13, 01:27 PM
liqB
liqB's Avatar
Default Diy Serpentine belt change 4GR-FE?
Does anyone have a DIY or a belt diagram for the 250? I didn't see any DIY's in the sticky for the 250, and for most searches Ive found instructions for the 350.
Old 06-09-13, 03:42 PM
Slammer1
Slammer1's Avatar
I prefer Gates belts, but love Dayco's website....
http://www.accessdayco.com/Auto.aspx
Enter your vehicle info and then click on "routing". Easy breezy.
Old 06-09-13, 03:43 PM
panda08
panda08's Avatar
drawing a picture before taking off the belt is the best thing you can do if you don't want to search for it lol.
Old 06-09-13, 10:34 PM
liqB
liqB's Avatar
Thanks dude!
Old 06-10-13, 05:34 PM
Gville350
Gville350's Avatar
The 350 accessory belt install will be basically the same as the 250. Relieve pressure on the tensioner pulley, removed belt, install new belt. DONE!
Old 06-10-13, 07:35 PM
Noeh
Noeh's Avatar
I had a Dayco belt on my other car, it squeaked like a pig after few months...
Old 06-10-13, 07:46 PM
Slammer1
Slammer1's Avatar
Thank you very much! Exactly why I prefer Gates. I have had the squeaking issue with Dayco in the past too. I have a Gates premium belt on my Honda with no issues, and if it weren't for the fact that I scooped up an OE belt up from Sewell a year ago and still have it ready for install in the garage, I would be shopping a Gates on the IS too.
Old 06-10-13, 10:32 PM
liqB
liqB's Avatar
I have a 250MT, and when I start the car in 2nd gear and the motor bogs down (<800ish rpm) because there isn't enough gas the motor starts making a pulley/belt chirp? belt/pulley issue or completely normal? I haven't been able to inspect my belt visually but am considering a belt change if it fixes this issue.
Old 09-03-14, 10:41 AM
mrfresh
mrfresh's Avatar
canucklehe
02-16-13 09:30 AM
mandyfig
06-06-11 08:40 PM
03LexIS300
IS - 1st Gen (2001-2005)
18
01-05-11 10:48 PM
carguy07
11-09-10 09:15 AM
acf
Maintenance
11-23-03 01:54 PM
Quick Reply: Diy Serpentine belt change 4GR-FE?
