Headlight Issues
Old 05-27-13, 09:11 PM
sallydrive
sallydrive's Avatar
Exclamation Headlight Issues
So a few weeks ago my passenger headlights beam pattern changed and it went all over the place as did the output decrease, so a few days ago I replaced it with some replacement Phillips from Amazon and the beam pattern is fine when you first put it in but then during a drive it changes and becomes bad and dim, I do not know what is wrong, any help would be greatly appreciated. Thanks guys!
Old 05-29-13, 10:03 PM
sallydrive
sallydrive's Avatar
anyone????
Old 05-29-13, 11:29 PM
lysis250
lysis250's Avatar
If you are still under warranty then go to the dealer, they'll probably just give you a new headlight.
Old 05-30-13, 06:47 AM
whitebeast
whitebeast's Avatar
Ballast could be bad. Have you try switching bulb Left to right?
Old 05-30-13, 09:39 AM
Mpatel1
Mpatel1's Avatar
Is the bulb all the way in the headlight assembly? It could be loose, so make sure the bulb is properly secured.
Old 05-30-13, 09:53 AM
my1s250
my1s250's Avatar
you prolly didn't seated it in all the way....does it shine on the ground with a black blob in middle ? the proper way is with the wire facing the rear of the car.
BCT
06-29-18 08:53 AM
myLexRX
03-26-18 11:52 AM
Armymedic
02-20-14 05:25 PM
RXSF
07-01-08 07:35 AM
qman2002
06-15-08 02:05 AM
Quick Reply: Headlight Issues
