Fast tap turn signal
Old 05-25-13, 08:54 PM
Bushum
Bushum's Avatar
Default Fast tap turn signal
Is this a setting the dealer can turn on? For those that don't know what I mean I am talking about pushing the turn signal lever down about half way and the signal flashes three times. My 02 and 04 Audis had this, my Mitsubishi had it, my wife's Hyundai has it, even my piece of crap Charger has it. I cannot imagine My 2011 Lexus doesn't have this option. Please tell me I'm overlooking something!
Old 05-25-13, 09:22 PM
Nikon
Nikon's Avatar
i wish mine had this.
Old 05-25-13, 09:25 PM
1sWt2GS
1sWt2GS's Avatar
you can hold it down slightly (not enough for it to lock) and let go once you finished changing lanes
Old 05-25-13, 09:56 PM
Bushum
Bushum's Avatar
Yes but that is true for any car. The fast tap is very nice for lane changes because you can immediately regrip the wheel.
Old 05-25-13, 10:02 PM
keyframe13
keyframe13's Avatar
I doubt it has it. I also wish the lever was more sensitive with the wheel. A bunch of times it stays on signaling and not returning back .
Old 05-26-13, 10:02 AM
Tapangb
Tapangb's Avatar
I believe this function is only standard on the 2013 Lexus models. It had it on the 2013 ES they gave me as a loaner but didn't have it on another 2012 ES loaner.
Old 05-26-13, 10:19 AM
Hoovey689
Hoovey689's Avatar
The LX, LS, GS, ES all have the 3 blink quick lane change. the 3IS also has it. 2IS does not.
Old 04-09-15, 08:56 AM
mitsuboost
mitsuboost's Avatar
Sorry to revive an old thread.
I'm almost positive that this can be done by using the 3IS blinker relay. I haven't done it myself but someone has out there I'm sure. Any takers?
Old 04-09-15, 09:38 AM
valeoray
valeoray's Avatar
I found this http://www3.telus.net/s_mcphee/tappage3.html
but it doesn't list the 2nd gen IS. Does anyone know if we have the 8-pin Denso flasher plug?
It works with LED bulbs too!
Also found this:https://www.clublexus.com/forums/lig...5-flashes.html
Old 04-09-15, 12:21 PM
Bichon
Super Moderator
Bichon's Avatar
Why are you positive this can be done?
My guess is that the wiper stalk and wiring harness would be different on the 3IS. The wiper stalk on the older cars latches mechanically when pulled all the way to signal a turn. Why would they put in a more complex switch and extra wires to differentiate between a partial and a full pull of the stalk, when the blinker module on the older cars does the same thing (i.e., blink), regardless of whether the stalk is pushed fully or part way?
Old 04-09-15, 12:22 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
The TapTurn has issues performing all of its functions on the 2IS because the turn signal uses the CAN-bus and is not active when the car is off (which is how the TapTurn is programmed). If you set the options like number of flashes, etc., in another car or manually with wires/switches it can be used in the 2IS, but it is not fully functional, which is why it is not listed as compatible on the website.
From what I've seen/looked at, none of the factory Toyota/Lexus options can be used on the 2IS, they are almost all done by the gauge cluster or similar and there is no separate flasher relay like we have.
Jeff
Old 04-13-15, 09:10 PM
mitsuboost
mitsuboost's Avatar
I'm not a car electronics guy so I can't say positive...I mainly posted to get the community to start talking about it. However it seems like there are more complexities than it may lead one to believe.
Old 04-21-15, 03:41 PM
codenko
codenko's Avatar
I have this on my 2IS with tapturn. While you can't control or configure the other features like number of times to flash and parking lights, it will add the 3 blink. I can make a video if anyone is interested.
Old 04-21-15, 03:44 PM
hirsch2is
hirsch2is's Avatar
I'm interested
Old 04-21-15, 04:45 PM
boystar22
boystar22's Avatar
If you plug the tap-turn relay into another toyota vehicle you can program it and it will remember the settings when you plug it into your 2IS. That is what I did with mine. I used my mothers Scion tC to program it then put it back in my car and now gives me four flashes to change lanes and it doesn't do the annoying illumination after you lock the car.
Quick Reply: Fast tap turn signal
