Any one with MOST AGGRESSIVE Wheels Set up on 2IS AWD
Old 05-18-13, 05:00 PM
dangerofs
dangerofs's Avatar
I like AndysIS set up, wt kind of wrk u have to do to fit them, n how bad is rubbing?
Old 05-21-13, 07:16 AM
mr250
mr250's Avatar
heres mine 19x8.5 +18 and 19x10.5 +25
and heres a rolling shot of her
Old 05-22-13, 10:02 PM
AndysIS
AndysIS's Avatar
Originally Posted by Stainless9
How are you guys riding that low with the AWD??
it just vibrates slightly, for some reason the awd does that
Old 05-22-13, 10:07 PM
AndysIS
AndysIS's Avatar
i had to roll the fenders and pull the fenders but i did a crappy job at pulling it no one up in colorado pulls fenders so i had to do it myself i tried to take my time but fitting 19x9.5 +15 needed a good pull i have slight bacon fenders not to bad but they dont look that great but no one says anything only just i notice it gana get it fixed later on thought after bags i hope
and rears i did a roll and pull but that wasnt enough i had to camber it at -6 but it dosnt rub to bad only when people sit in the back
Old 05-23-13, 07:38 AM
mr250
mr250's Avatar
Originally Posted by AndysIS
and a roll shot
How low are you I'm 24.5 in the front and 25 in the rear
Old 05-27-13, 10:03 PM
AndysIS
AndysIS's Avatar
i never measured it i just lowerd it untill i couldnt go lower from hittign the fender
Old 05-27-13, 10:41 PM
guesswh0
guesswh0's Avatar
How are your guy's cv boot holding up being extremely low?
Old 06-08-13, 02:11 PM
AndysIS
AndysIS's Avatar
mine tore once already but I hear that lexus makes a cv boot repair kit they told me they dont make.cv boots idk if its bs
Old 06-08-13, 06:57 PM
mr250
mr250's Avatar
mine is seaping from front the bands but only on the driverside inner
Old 06-08-13, 07:07 PM
reyoasian
reyoasian's Avatar
guys i'm planning to go 24.5" front and 25" rear
thinking of doing sa55m 19x9.5 +24
how to pull that off? (what tires, how much camber, roll/pull, etc.)
thanks
Old 06-09-13, 11:59 AM
AndysIS
AndysIS's Avatar
did you find out if theres a place that sells the cv boots? i had to buy a whole new axle when i changed mine
Old 06-09-13, 12:02 PM
AndysIS
AndysIS's Avatar
thanks
so 19x9.5 +24 all around ? i think you should stagger it but the fronts will just need some work like roll and slight pull but the back might not need much but if you stretch your tires and give it camber the less youd have to pull
Old 06-09-13, 12:45 PM
laobo979
laobo979's Avatar
Andy there are replace boots but not from Lexus. Cost is around $20 I think. Search the forum I post a link a few years ago on where to get them. It helped alot of member from buying a whole new one.
Old 06-09-13, 02:22 PM
mr250
mr250's Avatar
http://www.mylparts.com/parts/2006/L...20DRIVE%20AXLE i seen this place anf i think sewell has them to
Old 02-07-16, 05:49 AM
LexyIS250
LexyIS250's Avatar
Question
Originally Posted by xredgiex
I'm running 19x9 et 24 up front and 19x10 et24 in the rear, slammed on megan coilovers. Not as aggressive as I would like and it doesn't rub too much with the fenders rolled and stretched tires
What size tires sizes you running on? Im trying to go lower with tires tucked. Im on BC racing extreme lows rolled fendors front and rear.
Quick Reply: Any one with MOST AGGRESSIVE Wheels Set up on 2IS AWD
