LED decoders and heat
A while back I bought four LED turn signal bulbs from a member here on CL. He mentioned that I would need to buy resistors/decoders to make sure they don't hyper-blink or trigger any warning lights on the instrument cluster, so I bought a set of four from V-LEDs.
Yesterday I installed the rear turn signal bulbs. They work great, but the decoder has a warning that says that it gets pretty hot, so I should make sure its not touching anything flammable. Currently its sitting right against the trunk liner. Is it okay for it to sit like that if its connected to a turn signal bulb? I assume they only get hot when the light is on for a long period of time, like a DRL bulb? Can anyone with experience chime in?
This is similar to what I bought (different bulb socket). One end goes into the OEM bulb socket and the other end is where the LED bulb goes in.
Thanks!
Thanks!
Never used a decoder pictured like that, rather most ppl use a small resistor that you wire into the harness. The resistor does get hot but i've never had problems of it melting anything.
My suggestion - ditch the decoder and get the VLEDS flash relay. Simple plug and play and no more LED hyperflash or need to use resistors/decoders. Other companies make a flash relay also, but you will lose the lock/unlock flash confirmation.
VLED Flasher Relay: http://www.vleds.com/toyota-electron...ignal-fix.html
ninerfanAZ
Lighting
05-28-15 02:07 PM
bagwell
03-10-06 06:13 PM
