Error codes I retrieved from OBDII
Got my OBDII scanned because my car was throwing check engine light not too long ago. What are these codes?
O2 Bank 4 Sensor 4
Minimum sensor voltage for test cycle. Min: 22,808 max 53,286. Current: 56,224
I have a intake, F-sport axle back, and a midpipe.
O2 Bank 4 Sensor 4
Something like this:
http://www.ebay.com/itm/Torque-Solution-Universal-O2-Sensor-Extender-/400430804902?pt=Motors_Car_Truck_Parts_Accessories&hash=item5d3b892fa6&vxp=mtr
Or this
http://www.ebay.com/itm/1x-O2-Oxygen-Sensor-Extension-Extender-M18-x-1-5-Thread-Weld-on-Bung-Spacer-/230945004917?_trksid=p2045573.m2042&_trkparms=aid%3D111000%26algo%3DREC.CURRENT%26ao%3D1%26asc%3D27%26meid%3D6297889754850574461%26pid%3D100033%26prg%3D1011%26rk%3D1%26sd%3D230945004917%26
Or this
Your wrong on that note. Cause his primary cat is still there on the headers. The secondary sensor are before the secondary cat. So deleting them will never threw CEL. Only if your have issue with the primary will it go off or a bad sensor. I suggest OP go to autozone for a free reading. Like I said never heard of bank 4 or sensor 4.
You are right but I have seen this problem on my friend is250. He got CEL right after install mid pipe. However, o2 sensor extender fix the problem.
Anyway, head to local auto parts store and have them read the error code which is much more easy for us to help you out.
nicos1
10-08-07 12:44 PM
