Seeing is Believing: 358rwhp, 400rwtq Supercharged IS350 (DYNO'd)
Old 03-13-13, 10:00 PM
  #106
TravyTrav
TravyTrav's Avatar
Damn! Nice build.
Old 03-20-13, 10:05 PM
  #107
RobertCase
RobertCase's Avatar
Awesome build man. The numbers are incredible.
Old 03-28-13, 08:55 PM
  #108
stewb10
stewb10's Avatar
Another update:
Had to add another idler pulley to the bracket, because I kept throwing belts left and right with the stiffness of the industrial 8-rib over the normal 6 rib i was using. We should've designed the bracket with the pulley on top, because the clockwise crank rotation would act as a force to tighten the belt under load. However, had we did that, wed sacrifice a lot of convenience when it comes to adjusting and removing the belt.
Now Its staying on, but the belt is long enough that i can't get quite enough tension without risking having the belt touch in the middle, but i also got shipped another 75mm pulley (8.5psi) instead of an 80mm. Luckily, I'm getting more than enough belt slip to keep me in the green. The 80mm will be in soon, and I'm hoping it will afford a consistent 7.5-8psi. Then ill grab a dyno and this project will be finished!
After that, I'm doing one more round of cosmetic mods in the near future, and then I'll start looking into headers, then maybe an LSD.
The car is still VERY fun to drive, because boost builds to 5psi low in the RPMs then depending on throttle pressure, stays there or starts to fall off over 4500rpm. Still getting plenty of torque out of this thing. And it truly feels like a stock is350 with a 100hp bump. No reduction in driveability.
Old 03-28-13, 09:04 PM
  #109
heyarms
heyarms's Avatar
Originally Posted by stewb10
Another update:
Sorry to hear about all your belt slippage. Whatever contraption Mike sold me works flawlessly. Just hit 7,000 miles since boosting. Ill be happy for you once it's all dialed in and works all the time. Keep at it, and no joke about the car being fun to drive. Mines a 250 and its loads more fun, if only it was a 350... Lol good stuff here tho!
Old 03-29-13, 08:01 AM
  #110
joedr
joedr's Avatar
Damn! 400 tq? Niiiiiiiiice!
Old 03-29-13, 04:58 PM
  #111
mikellucci
mikellucci's Avatar
Hey Stew, I hope you get the 80mm soon! Here's how I ended up with mine... I drilled and tapped a higher hole for the top tensioner. I was going to use a 3.5" but I could barely get the 2 3" on. That green belt is nasty! Lol
Old 03-30-13, 07:29 AM
  #112
MikeyK02
MikeyK02's Avatar
Beautiful build!!
but even more so GO BUCKEYES!!!
Old 04-30-13, 07:24 PM
  #113
stewb10
stewb10's Avatar
well, now the cat is out of the bag mike
UPDATE:
Installed 80mm pulley for a consistent 7.5psi. That's where she will stay. Next steps are to finish off exterior mods, and I'm also considering some lighter wheels. Can't think of anything that will look as good though, and be under $3k. Open to suggestions. Really like concave, obviously, but you know what they say: Light, cheap, strong. Choose two.
Example, a set of used Volk GT-V.
Old 04-30-13, 08:54 PM
  #114
ernestfyu
ernestfyu's Avatar
UPDATE:
Check out the new forgestar f14 extreme concave. I'd really like to see a set of those on an ISx50 and they're usually pretty light weight.
Old 07-01-13, 08:06 PM
  #115
stewb10
stewb10's Avatar
UPDATE: Went with the Work Emotion CR Utimate in GT Silver. The rears have the new Ultra Deep Concave face.
19x9.5 +25
19x10.5 +22
Wrapped in 225/35 245/35 Hankook V12.
All i have right now are some instagram shots. I'm going to be doing an AIT front lip and GFX rear as soon as the money from the Vossens hits my account from paypal. After that, ill give her the shoot she deserves.
As a side note, i did weigh the setups, and i saved 5lbs overall each corner. Also, in the rear, i shaved over an inch off of the overall tire height, which I now think its part of the butt dyno difference I perceive between my 18" winter setup and the 20" Vossens because of gearing.
Also, i WILL be getting center caps.
Old 07-01-13, 08:24 PM
  #116
edgeucated
edgeucated's Avatar
works rims look great!
However, i would have gone with a tad bit less aggressive setup to have more tire. With the amount of torque your getting, it would be nice to put it all down on the ground
Old 07-01-13, 08:28 PM
  #117
stewb10
stewb10's Avatar
Actually, not an issue. I'm not running near as aggressive camber as many people with that offset. I did a fender pull instead. That being said, the Hankooks in a 245 hook FAR better than the FK452 ever did, even in a 275 with less camber, which is what i banked on. Form+Function.
Trac on, i barely get any wheelspin, as expected. Disabled with the pedal dance, I used to end up spinning so much I'd bounce off the limiter from a 2k launch. Now I can launch at upwards of 2.2k without such issues. I can basically launch as hard as the rear brakes will allow without starting a brake stand, even after revving it up in neutral to sink the brake pedal deeper into the floor.
Old 07-01-13, 10:39 PM
  #118
RVCAis250
RVCAis250's Avatar
I've always loved those wheels, I actually still want a set.. looks really good
Old 07-05-13, 09:41 PM
  #119
blackgpgt
blackgpgt's Avatar
In an earlier post you said you relocated the bumper tabs...anyway you can give me some info on how you did so... Thanks in advance! Awesome setup btw
Old 07-05-13, 10:09 PM
  #120
tripp
tripp's Avatar
pretty cool
Quick Reply: Seeing is Believing: 358rwhp, 400rwtq Supercharged IS350 (DYNO'd)
