Removing mods before dealership visit
Old 12-28-12, 12:29 PM
04WDPTL
04WDPTL's Avatar
Default Removing mods before dealership visit
I recently purchased a 2007 IS350 with 55k miles. From what I've read the car should still be under the 6yr/60k powertrain warranty. When driving the car, i've been noticing hard shifting primary on gears 1-3 and especially when rolling to a stop sign and accelerating from a slow corner.
I am planning on bringing the car into the dealership to have the transmission checked. Before I do, should I remove the mods that was installed by the previous owner just in case they blame it on the after market parts? The car comes with F-sport exhaust and after market intake.
Old 12-28-12, 12:35 PM
bob4256
bob4256's Avatar
Your only mods are exhaust/intake?
The only way the dealer will void any type of warranty is if the modified part caused that part or other related parts to have issues.
If you have an aftermarket exhaust and your nav screen dies, they cant blame that. But if your cats fail or you get a bad 02 sensor, thats sometihng that could be potentially blamed on the exhaust
Old 12-28-12, 12:46 PM
KillaIS250
KillaIS250's Avatar
^^ He is right. They cannot void your warranty on something just by having aftermarket parts present on the car - unless the aftermarket part caused the failure. The exhaust and intake mods would not cause a failure in the transmission. For something like a transmission to be voided/not repaired under warranty due to mods, you'd have to have something like a turbo or supercharger present that would be capable of causing damage to the transmission.
There's a law that applies to these kinda situations:
http://en.wikipedia.org/wiki/Magnuso...s_Warranty_Act
http://blog.blackdogspeedshop.com/20...your-warranty/
Old 12-28-12, 01:29 PM
04WDPTL
04WDPTL's Avatar
I have other minor mods that would not be applicable in this situation such as lights, and alarm. Only intake and exhaust mods to the engine.
Is this a common issue with the isx50?. I tried googling the issue and only found 1 other with similar issue.
Old 12-28-12, 01:43 PM
bob4256
bob4256's Avatar
The common issue with 250s is carbon buildup causing rough ide, but it sounds like your having tranny problems
Old 12-28-12, 01:53 PM
accelerate
accelerate's Avatar
I have a question are you driving your car with the power button on. Because if you are those are the symtoms you will feel.
Old 12-28-12, 02:35 PM
04WDPTL
04WDPTL's Avatar
Power button is off. I've also reset the ecu, but did not notice any improvement.
Old 12-28-12, 03:40 PM
reyoasian
reyoasian's Avatar
Not to mention it's FSport exhaust....Lexus Certified!!!!
Old 12-28-12, 04:16 PM
Shervin350
Shervin350's Avatar
have you reset your ecu since you got it, maybe the previous owner drove it aggressively, i say reset it and drive it for couple of thousand miles and see if it fix ur problem
Old 12-28-12, 06:53 PM
Sffd103
Fire Slayer
Sffd103's Avatar
Good luck with your visit to the dealer. Hope all goes well.
Old 12-28-12, 08:55 PM
peyman
peyman's Avatar
u just turned a light bulb on in my head. thanks!!
Old 12-29-12, 07:42 AM
04WDPTL
04WDPTL's Avatar
I've reset the ecu by disconnecting the battery from the car for about 5 minutes before putting it back. Is this the correct way of resetting the ecu?
I've only driven the car the for maybe 400 miles after the ecu reset. Does it really take a few thousand miles for the car the learn my driving habit?
Old 12-29-12, 11:02 AM
NimaM
NimaM's Avatar
I think it all depends on the dealer and the type of mods you have on the car. If you established a good relationship with the dealer, they may not be picky about mods. My dealer wasn't picky at all.
Old 12-29-12, 11:15 AM
600rr05
600rr05's Avatar
you will be fine since they are F sport parts..
bob256k
07-24-18 07:23 PM
kevinisbae
07-27-17 07:52 AM
tcoff09
01-12-15 05:16 AM
Mr_VFS1
09-11-13 03:21 PM
sosobri805
Performance
10-25-10 02:53 PM
Quick Reply: Removing mods before dealership visit
