My aftermarket subwoofer setup
Old 12-12-12, 08:35 PM
CCJ22
CCJ22's Avatar
It baffles me how many people ONLY tap the stock subwoofer and not the 6.5" door speaker as well.
Also, J do you have the ML audio or non ML audio?
Old 12-25-12, 10:06 PM
vapid2323
vapid2323's Avatar
Ok I was just checking this setup out, I have been out of the game for a while but do you think a 50 pound sub is a good idea to toss into a thin box like that? I guess I would be concerned that it might just pull right out of the enclosure with a few good speed bumps lol.
Old 12-26-12, 02:32 AM
jsmacks
jsmacks's Avatar
It's not all that thin and it's good quality high density particle board. It's fine..
Old 04-18-13, 09:22 PM
ChanceG
ChanceG's Avatar
Originally Posted by jsmacks
What wires are you tapping for your line out converter? When I had just the stock sub wires tapped, the bass output was very low and low only. That's why I went back and tapped one of the rear door subs in conjunction with one set of stock sub wires. This gave way better response. Try also not disconnecting your stock sub and running it together with your aftermarket sub. My head unit sound levels are bass: 0 mid: -1 treble +4
Also make sure that your amp crossover is set all the way up to 250Hz and that your bass boost is set all the way down.. as that usually increases only the lower bass around 40Hz.
About to rewire and install a new sub and custom box.
Which speaker to tap with the stock sub, Front door or rear door speaker???
TIA
Old 10-24-13, 04:28 AM
tn96dc
tn96dc's Avatar
still waiting for pics :P
badboylex
IS F (2008-2014)
09-18-17 11:26 AM
pikes
ES - 5th Gen (2007-2012)
14
01-30-14 04:04 AM
Rozay604
RX - 3rd Gen (2010-2015)
10-26-13 03:33 AM
JPZEE83
08-14-10 12:13 AM
Quick Reply: My aftermarket subwoofer setup
