frozen rear calipers
Old 10-15-12, 02:00 PM
kuuqi
kuuqi's Avatar
Default frozen rear calipers
hey guys,
i'm attempting to change my brake pads and realized my rear caliper is seized and it's preventing me from fitting my outer pads.
any idea how much i should pay to have it replaced? the hub is fine but i'm trying to figure out what part(s) i need to rebuild a new caliper. or i might just pay a shop to do it.
thanks!
Old 10-15-12, 04:01 PM
GiantsFan
GiantsFan's Avatar
You might be covered.
https://www.clublexus.com/forums/att...9lb-0001-w.pdf
Old 10-15-12, 04:44 PM
Clay Easto
Clay Easto's Avatar
My rear calipers were seized up and replaced for free under the Lexus extended warranty this past summer. It might have been done under the campaign posted above, but the dealer did not state that.
Old 10-15-12, 07:45 PM
ecr527
ecr527's Avatar
This happened to my car as well. I brought it in to the dealership as I thought it would be covered, but then they told me that they inspected them and applied grease to the slide pins when I was in for a different TSIB a couple years ago, so now it's not covered and they wanted $900 to replace both calipers. I ended up buying replacement calipers from Sewell and just replaced them myself.
Old 10-16-12, 04:59 AM
willi3ja
willi3ja's Avatar
Mine were seized as well. Picked up a pair from Rock Auto. Word of advice though; you may want to paint them before you put them on, as mine are already rusted on the outside after just a couple months.
Old 10-16-12, 05:47 AM
SeanIS350
SeanIS350's Avatar
Both of mine were replaced under warranty
Old 10-16-12, 12:56 PM
Gville350
Gville350's Avatar
I'll be doing my rear pads coming up at the end of this month. I hope to that the TSIB for the new replacement rubber boot fixed my rear calipers from having this issue. We shall see!
Old 10-17-12, 12:05 AM
ibidu1
ibidu1's Avatar
Take the caliper completely off put it on a vise, Get a propane torch and heat only the part with the pin. Spray some PB blast keep trying to work it but leveraging the caliper or put it on a vise. It will free up, just have to put time into it. Once you have it free and separated, clean the pin and the inside of the shaft with steel wool and put a lot of grease in there.
BTW Most auto part stores carry the pins there like 9 bucks. I think calipers were 90 bucks each.
Worked like a charm for me! Took me 1-2 hours to free them up
Old 11-04-12, 11:23 AM
Gville350
Gville350's Avatar
Well, it took me 2 days of my 4 day weekend but I am STILL ON STOCK ROTORS AND PADS! Story goes, I installed my new Power Slot slotted rotors and Axxis Ultimate brake pads in the rear and buttoned everything up yesterday. Took it for a spin for the usual break-in procedure. Came back home shortly only to find that both calipers/pads were still smoking! I know new pads will smoke some, but NOT THIS BAD! I took a handy spray bottle and squirted the caliper/rotors; OMG, I've heard steaks on the grill sizzle less! Parked the car in the driveway, not the garage like normal, as the smell and smoke was still too much to bare. Let it sit overnight to chill. And now for today. First, after removing the driver side wheel I find that the caliper was heated up so much that the 900 degree caliper paint had bubbled off! WOW! Steel wire brushed that stuff off, and now on to the seized caliper. I did the above, minus removing it from the brake lines, and no dice! Even used PB Blaster. The caliper is in a permanently seized status; time for some new rear calipers. Well, to get me by until I can get the new calipers I re-installed the OEM stuff; all is fine.
At this point I'm seriously thinking that I'll be visiting Lexus in the morning, as this vehicle had been in to Lexus back in 2010 for the rear caliper boot TSIB. Obviously they didn't fix it right. So I'm left wondering what the chances are that I could get Lexus to cover the replacement of the calipers? Is it worth my time?
Hope you enjoy my misery! LOL!
Old 11-04-12, 12:52 PM
Likwid XTC
Likwid XTC's Avatar
I had the same problem you just encountered. Was changing my brakes and rotors found out that the rear calipers on both seized up. I read about the tsib and honestly it's not worth my time as I bought them from rock auto and used 2 day shipping (I need my car I work 25 miles from home and was using my dads v8 tundra. Gas was crazy)
260 ish with 2 day shipping and once I gr my credit back for the cores total cost would be 110 cause unused 2 day shipping with out shipping 62 bucks. Going to Lexus from my house would cost 20 bucks and waiting for them and going through the hassle. Not worth the time, ill spend the money.
drgrant
03-31-19 12:26 PM
maimou
GX - 1st Gen (2004-2009)
03-31-17 12:12 PM
iGS430
01-19-15 04:46 PM
EXL124
Suspension and Brakes
15
05-20-13 02:46 PM
BernieIS
02-21-12 12:24 PM
Quick Reply: frozen rear calipers
