Anyone have this problem when do carbon wrap center piece interior
This is 3rd I re wrap center piece.I did the job so perfect then I put everything back.after a week the carbon wrap move a lil away by shift edge.i used supper clue and it still move.i know the carbon wrap move because the heat when I park outside.anyone have this problem.it really bug me when I look at it.
don't use glue. Properly clean and dry off your panel with alcohol before applying the vinyl. After wards lightly spray it with 3m adhesive spray/promoter after that apply the vinyl and slightly blow dry it from a far at low heat
and if you really think its heat from the sun I suggest you get the shade cover for your dash, tint your windows, maybe even open your sun roof a little to let some air circulate
welp best bet is to get real carbon fiber pieces then, or the carbon fiber overlay, or make your own
https://www.clublexus.com/forums/clu...bon-fiber.html
http://www.cargym.com/lexus-is250is3...it-p-1327.html
http://www.carid.com/2006-lexus-is-w...em-454513.html
https://www.clublexus.com/forums/is-...bon-fiber.html
Did you buy the pre-cut carbon fiber overlay or did you cut it yourself?
I bought the pre-cut kit and it wraps over the edges of the trims. So I tuck the excess underneath the trim instead of cutting it off with an exacto knife. I think the key thing is to take your time applying it on, making sure you smooth it out to get rid of any air bubbles. I haven't had any problems for almost 2 years since I installed it, regardless of heat/etc.
Try 3M primer 94 if you are having problems with the vinyl adhesion...
http://www.lamin-x.com/3M-Primer-94-...oz-p/tl207.htm
(you can get it on eBay for cheap)
vboi4life
09-25-12 12:39 AM
