IS250 Carbon Build up CSP
Old 05-20-13, 10:04 AM
  #616
NQR89
NQR89's Avatar
I agree, I had my water pump and belt replaced. They didn't charge me for labor so it's good, I think it'll be the same case with you.
Old 05-20-13, 10:44 AM
  #617
keyframe13
keyframe13's Avatar
Just curious, were you out of warranty. I know water pump should be covered under warranty, 70k miles
Old 05-20-13, 11:14 AM
  #618
NQR89
NQR89's Avatar
I'm way out of warranty. I have 140k miles and I got the car in 2006.
Old 05-20-13, 12:03 PM
  #619
lexudv
lexudv's Avatar
Dropped my car off on Sat after i got the check engine light and just got a phone call that my car was approved for the repair by Lexus. Supposedly the computer indicated a lot of major misfire issues and because of that, they can fix it ASAP. I asked about the timing on the parts and they said they should have it done by the end of this week!
They did ask about replacing the spark plugs and water pump, but I declined since I already replaced those myself. Might have them replace the accessory belt though since I didn't replace it when I changed the water pump.
Hope I get my car as good as new. It's been good to me so far the last 7 years!
Old 05-28-13, 07:15 AM
  #620
colbond
colbond's Avatar
Originally Posted by KillaIS250
Check the water pump for leaks, it might be a good time to replace it too anyways since its a fairly common failure for the 2IS. Like Clay posted earlier, they should charge you just parts. Same for the spark plugs... if you haven't already changed them might as well as long as they charge for just parts. I would also have the accessory belt done, relatively cheap part and again the labor should be free anyways.
Thanks for the input. The water pump had a very small leak so I went ahead and had it replaced. The tech pulled out the old plugs which the previous owner had replaced (I've probably only put 5k miles on it since I've owned it) and they're some cheap-o plugs they installed - having those replaced with the stock denso iridium. I had him check the belts and everything looked good. Should be picking my car up this afternoon. I dropped it off on 5/16 for them to check for the carbon build-up issue and they called me 8 days later that it was ready to go.
Old 05-30-13, 07:33 PM
  #621
meis250
meis250's Avatar
On my 07 is250 I had the top engine clean done in Oct. Up until now, I had two instances where car almost stalled when stopped at traffic light. I have an appointment at the dealer next Friday morning, I have no lights/ errors coming up (never had). What should I expect? Car was still under warranty in Oct, not anymore now.
I don't just want to pay the 125$ for a check.
Anyone has experience with this? Thx
Old 05-31-13, 06:16 AM
  #622
is250gurl
is250gurl's Avatar
it's a known issue that is covered by a tsb and since you had issues while in warranty i don't see them denying you. i would be vocal about it and call lexus corporate if the dealership says no.
Old 05-31-13, 07:05 AM
  #623
graphX250
graphX250's Avatar
Like driving a new car!!! . Just got my car back, replaced pistons,water pump, etc. all of it was covered!
Lol. Asked if they reset the odometer too!
Old 05-31-13, 07:53 AM
  #624
B16da9
B16da9's Avatar
They wont rest the odometer as the vehicle physically has the mileage on the odometer. What you should do is keep the paperwork that identifies the mileage at which the engine was overhauled for this issue.
Old 05-31-13, 08:00 AM
  #625
keyframe13
keyframe13's Avatar
LOL, you didn't feel the sarcasm in there did you?!
Old 05-31-13, 08:02 AM
  #626
B16da9
B16da9's Avatar
nope it literally went right over my head lol
Old 05-31-13, 08:11 AM
  #627
is250gurl
is250gurl's Avatar
it was like driving a new car for awhile, but then the rough idle and shaking at lights will return unfortunately. it's not a permanent fix. really disappointed in this aspect of the car and doubt they fixed the issue in the new model coming out soon.
Old 05-31-13, 08:33 AM
  #628
graphX250
graphX250's Avatar
Said they also cleaned the top end again, I'm guessing that it is part of the repair and not something extra they did.
Old 05-31-13, 12:52 PM
  #629
Fizzboy7
Fizzboy7's Avatar
I'm holding off on the rebuild as long as I can. All these large repairs is not going to help resale value if someone has access to a computer and your car's records. =(
Old 06-03-13, 05:34 PM
  #630
sti101
sti101's Avatar
I am just wondering did they charge you the labor to remove and install the water pump? My is250 is in for piston replacement, but the dealership wants to charge $160 + labor to do the water pump...
Quick Reply: IS250 Carbon Build up CSP
