IS250 Carbon Build up CSP
#241
I drove my car a little hard this morning to get past a group of slow-moving cars on the highway, and when I came to a stop I think I felt the engine misfiring for a few seconds. When something like that happens, it's logged into the car's computer right? So if I take it to my dealer they should be able to check the history and see that it misfired?
#243
Nice. Longo did the work on my car too. Your car is in good hands
#244
#246
My low-mileage 2008 has had this problem since 16k miles, or since 2010. What could possibly be in question? Unless they are thinking because a car is driven less, it automatically has not had a chance to blow out the junk built up inside??? I have yet to receive anything in the mail as far as the warranty extension goes...
#247
I'm curious why a low mileage unit would be turned down. The fact that a "fresh" car was already experiencing the problem would reflect the magnitude of the carbon build up problem.
if you have the problem and your dealership has their **** together, it should be approved. it sounds like Longo knows what they're doing. based only on this forum.
#248
low mileage cars are a lot less likely to have enough carbon built up to cause the issue. that being said, low mileage cars are sometimes driven on very short trips (10 miles or less), which contributes to carbon buildup. there have been plenty of cars with 20k on them approved for the piston and ring replacement. 1 low mileage car not being approved simply goes with the odds.....and trust me.....there are plenty of owners that are simply imagining the misfire.
I've been working with Longo and one other dealer for a few years now. So far my car hasn't given a strong enough code to qualify for anything other than two top cleanings. But make no mistake, it has the problem. When the car starts shaking violently at a stop and almost stalls, it's not imagination. Others? I can't speak for them.
#249
No problem man. They weren't too bad to be honest, I didn't notice it very often until after they did the top engine clean... Then I would notice it idle when braking almost every time. Uhm it might of just been my car, but other than having the RPM's drop really low I noticed that accelerating/changing gears were a bit clunky every morning till a few minutes of driving, this might of been due to the fact that the engine wasn't completely warmed up yet but I only noticed it after the top engine clean.
#250
That drive pattern you just described is exactly how the carbon misfires typically happen. In fact the duplication procedure is supposed to simulate steady highway driving, followed by full power, then coming to a stop. your dealer does not need to see a history. Just tell them exactly what happened. there are a lot of people reading about this CSP and imagining the misfire condition or noticing slight vibrations that they never really noticed before. Based on your story...There's pretty much no doubt that you experienced the exact condition the CSP is for. No hurry though. 9 years gives you plenty of time.
#251
I never received the letter from Lexus for this issue and when I login to my Lexus account it states:
I have a 2007 IS250 which I bought 12-2011 as a CPO. It did have the top engine cleaning.
Your vehicle does not require any outstanding safety recalls or service campaigns at this time. This inquiry covers all recalls or campaigns currently not completed for your specific vehicle identification number (VIN).
#252
That's because this CSP does not fall under the recall or service campaign category. It's separate. I keep forgetting to upload the letter myself, hopefully I remember tonight when I am home, but you can always call Lexus Corporate if you are concerned about not getting the letter yet.
#253
I say all this because it directly relates to the carbon build up issue. It's not a recall because not all cars are affected. Only cars that underwent the right combination of circumstances to cause excess carbon buildup.
This is why you shouldn't assume you have the problem and shouldn't treat it like a recall (and just take your car to a dealership).
If you have experienced the rough idle/misfire, then bring your car to a dealer......this CSP is for you.
#254
i received the letter today and had a top engine cleaning done a few years ago when my car was really quite new. i haven't had problems since, and hope not to in the future, and while i'm still covered under warranty, the letter is reassuring.
#255
I had couple of rough idle but no code or anything shows up on the dash board...I do have a couple of videos...I've called the dealership today and said they'll run the test and see if I qualify...if I do..they'll order the parts and ill take about 4 weeks to get it.. the probelm is if I don't qualify..what now?
