Front Fenders Liners
08-31-12, 11:15 AM
So I added spacers to the front, and I am getting slight rubbing from my wheels. Anyone simply just remove their fender liners (I got rid of mine completely when I had my prelude)?
08-31-12, 11:28 AM
Why remove them if you only get rubbing during hard cornering? Or with your offset and spacers are you getting constant rubbing?
08-31-12, 11:46 AM
Just leave them on. It will work itself out if it's just slight rubbing lol.
08-31-12, 12:33 PM
I have 18x9 +12 front (after 20mm spacers). i hear rubbing as I drive, not loud, but noticable.
08-31-12, 01:26 PM
Heat it and bend it back some
08-31-12, 01:36 PM
if it's only slightly rubbing just do what he said^^ and heat them up and push em back, I had severe rubbing so I simply removed them completely lol I'm also running 19x9.5
08-31-12, 01:54 PM
^Since you say you have removed yours completely, have you have any ill-effects from doing that? I fear getting moisture in the fog housings and extra debris in the engine bay.
08-31-12, 02:28 PM
Fire Slayer
I rubbed through mine till there was no rubbing! Turn up the music and rubbing all gone. I just made sure it wasn't my fender.
08-31-12, 02:33 PM
man if its just fender liner rub through that **** till you dont hear it no more.
or you can be a little less barbarian and heat them, push them back and immediately spray them with cold water.
09-01-12, 05:59 AM
Quote:
Originally Posted by
Vroomin350
probably going to just let it rub...
09-02-12, 01:30 PM
Remove ur fender liner. Then u can have fun hearing rocks and other things fly up into your car.
09-02-12, 01:51 PM
Let it rub itself away and you wont hear it anymore. Looks dumb when the liners are removed.
09-02-12, 03:13 PM
I would heat it up and push it back.
Over here in Australia its illegal to run without the liners =S...plus it also protects your cables from mud/rain n all that road stuff.
09-02-12, 06:04 PM
Those with the rub-thorugh method, do you have any problem with rain/moisture getting into the wire loom or fog lights under the bumper??
09-03-12, 11:04 AM
^Nope, nothing. Got aftermarket HIDs in the fogs, and they still seal well with no moisture issues. The only issue is the fact that when I have passengers they kinda freak out when they hear something when going around a corner. LOL!
Ling2IS
12-21-16 08:09 PM
TISF
IS F (2008-2014)
26
01-18-16 10:14 AM
tony808
04-22-14 10:58 PM
JRumbarto
04-06-13 09:36 PM
VJZ
SC- 1st Gen (1992-2000)
20
03-08-09 10:09 PM
