Tire Pressure Dash Light
bob4256
I had my FlyAudio unit installed yesterday, and today the Low Tire light came on.
I checked the tire pressure on my tires and all are well.
I also checked the TPMS System and it appears to be connected.
But I saw that you talked about the ABS cable.
What would be the ABS cable? Is the cable that connects to the TPMS (right on the back of the unit)?
bob4256
yes its a cable that connects to the upper portion of head unit / navigation
This happened to me also... But I deflated my tires to 28Psi then pressed the custom button on the left side of the driver dash next to the gauge brightness and selected tire pressure. Then I held down the button to set the default to 28psi and went to the gas stations and put my tires back to 32 psi. I am assuming that when you disconnected the wiring for the head unit, it reset that tire pressure as well? Whatever it was it fixed the issue for me.
jrs21c
11-27-19 07:39 AM
