need HID bulb replacement recommendation
Old 08-23-12, 07:41 AM
SpaceCadet
SpaceCadet's Avatar
Default need HID bulb replacement recommendation
One of my headlights is out. Sewell price is $175 each. Are there any aftermarket ones that are recommended?
Old 08-23-12, 07:43 AM
bob4256
bob4256's Avatar
Im guessing your car came stock with HIDs? D4S bulbs?
If so I know a lot of members here like Garax bulbs
Old 08-23-12, 07:48 AM
SpaceCadet
SpaceCadet's Avatar
Its stock for sure but dont know if its D4S
Old 08-23-12, 07:58 AM
SpaceCadet
SpaceCadet's Avatar
will this work
Amazon Amazon
Old 08-23-12, 08:21 AM
bob4256
bob4256's Avatar
If your came stock with HIDs yes those will work. You may get better pricing if you look in the vendor section
Old 08-23-12, 08:34 AM
Sango
Sango's Avatar
You can get Philips Ultinon 6000K from CL forum vendors Nigel-JDMParts or XenonDepot.
Old 08-23-12, 08:35 AM
Timbo02
Timbo02's Avatar
I got mine from amazon, search for Philips D4S Xenon HID Headlight Bulb. They are $50.86 a bulb.
Old 08-23-12, 08:49 AM
SpaceCadet
SpaceCadet's Avatar
is the factory bulb 6000k?
Old 08-23-12, 08:53 AM
JDKane527
JDKane527's Avatar
Philips or Garax
Old 08-23-12, 09:12 AM
Sango
Sango's Avatar
The factory bulb is not 6000K. It's about 4300K .
I would be cautious of Amazon since some of the vendors sell fakes, especially when it comes to the Ultinon line. The XenEco, not as much.
I would still recommend the two CL forum vendors to be the safest and reliable.
Old 08-23-12, 09:14 AM
bob4256
bob4256's Avatar
Most likely that was a knock off brand claiming to be Phillips. I believe those bulbs retail for about $200 because they come straight from Japan. Someone correct me if Im wrong
The factory bulbs are between 4100-4300K
Old 08-23-12, 09:27 AM
Sango
Sango's Avatar
Most likely counterfeit. Ultinon sell for almost $230-240+ a set and the XenEco is about $79 per bulb.
Old 08-23-12, 09:45 AM
bob4256
bob4256's Avatar
Old 08-23-12, 09:54 AM
brociouz
Uber 1337 Moderator
brociouz's Avatar
OEM HID bulbs are 4100K Philips D4S 42V 35W XenEco bulbs.
The best bang for your buck is Garax bulbs IMO.
Old 08-23-12, 10:00 AM
Timbo02
Timbo02's Avatar
They could have been, they were identical to the ones that I pulled out of the car though. Then again it's getting easier and easier to make fakes identical to the original. It also said the seller was Amazon.com not one of the vendors, so who knows.
Quick Reply: need HID bulb replacement recommendation
