Aftermarket axle shaft?
Old 04-30-14, 05:56 PM
maniacbob
maniacbob's Avatar
Default Aftermarket axle shaft?
My axles are clicking on turns and I know the rear ones are leaking. I know you can drive it like this fine for awhile, but I just want to change it out. How are aftermarket ones compare to oem? Obviously aftermarket is much cheaper compare to oem, so would it matter to go aftermarket?
Thoughts would be appreciated. Thanks!
Old 04-30-14, 06:10 PM
Gville350
Gville350's Avatar
Reman half shafts are usually OEM cores that are cleaned, inspected, and re-packed with grease. So mostly OEM components with fresh grease. I'd go with AutoZone reman half shafts, as they come with a lifetime warranty. I used such warranties ALOT when I was working on my Hondas.
Old 04-30-14, 06:20 PM
maniacbob
maniacbob's Avatar
Good thinking. Lifetime warranty will be great.
RickHansen
RC - 1st Gen (2015-present)
11-19-17 03:17 AM
maxwebr
02-04-12 04:18 PM
EdSC2JZ
SC- 1st Gen (1992-2000)
11-16-10 06:42 AM
Nosferatu2
10-06-09 01:09 PM
Quick Reply: Aftermarket axle shaft?
