brake problem possibly need advice
I went to drive my car today (IS250 2008) and i made it around the block before I heard a beeping sound and my car started to make choppy stops. It happens at random speeds and its like when you try to stop on ice and you feel your brake pedal become choppy as you stop. Does this sound like it could be fixed with replacing my brake pads or something else? I get no warning lights on the dash just a rapid beeping noise.
naw i know for a fact that they overprice everything and changing brake pads is something i can do i just need more confirmation on it. it sounds like it is because the front pads look really low, but the rotors have no scars or signs of the brake indicator touching it nor do i hear any screeching or squeals when i stop.
ok nevermind i solved the problem after checking out the forums. turns out all i had to do was reset the battery and that somehow fixed it...but now I need to do some serious maint and clean/change some stuff...
SNORTH350
Suspension and Brakes
20
12-01-12 04:10 PM
