Thinking about replace my OEM front and rear tweeters and speakers, need help!
Old 06-24-12, 02:29 AM
kim0217
kim0217's Avatar
Default Thinking about replace my OEM front and rear tweeters and speakers, need help!
Wondering what size should I buy for the front and rear tweeters and speakers? And any recommendation for the IS? Thanks a lot guy!
Old 06-24-12, 10:55 AM
Gville350
Gville350's Avatar
If you are still on the factory amp, with good functioning tweeters, there's no need for getting any others. In fact, if you get another set that isn't the exact factory spec (ohms/watt/size/etc) could downgrade the sound quality.
Just my $.02
Old 06-24-12, 11:27 AM
RDIS250AWD
RDIS250AWD's Avatar
Just my $.02
+1 my thoughts exactly
Old 06-24-12, 02:11 PM
Toxicxk23
Toxicxk23's Avatar
can a subwoofer be hooked up to the factory amp? or would I still have to get another amp?
Old 06-24-12, 04:28 PM
kim0217
kim0217's Avatar
Just my $.02
Thanks for the input, I'm definitely gonna run aftermarket amp for the the speakers or tweeters, just don't know what size or what brand would fit perfect on the IS.
Old 06-24-12, 08:23 PM
stasis3131
stasis3131's Avatar
You need another amp to drive another subwoofer
And to the op I would replace what's still working cause Lexus speakers are on par to most 300 buck component sets. If they happen to blow then explore swapping them out for some Polk audio/mb quart/ or alpine speakers in the doors but you wasting time and money swapping tweeters
Old 06-24-12, 09:24 PM
Sffd103
Fire Slayer
Sffd103's Avatar
you should have heard mine today at BOS. I had factory speakers (non ML) before with a JL Audio 12W6 and I waned more do I upgraded the front mids and highs. Rears are mostly just fill.https://www.clublexus.com/forums/lex...with-pics.html
Old 06-25-12, 10:02 AM
w0rtez
w0rtez's Avatar
What if i want to stay OEM, where could i get the speakers and tweeters from... Just replace the damaged ones and put new ones in...
Thanks.
Old 06-25-12, 05:23 PM
Toxicxk23
Toxicxk23's Avatar
So how would I go about hooking up an amp and sub without replacing the head unit. I want to keep the dash looking stock.
Old 06-26-12, 02:17 PM
Gville350
Gville350's Avatar
I've heard other members using a JL Audio Cleansweep, but I'm sure there are cheaper alternatives to accomplish your goal.
Old 06-26-12, 02:39 PM
FSportIS
FSportIS's Avatar
As other members mentioned, the mids and highs in Lexus system are on par if not better than the good after market ones. This is also one reason I chose Lexus IS over other similar cars.
I highly recommend you upgrading the sub-woofer set up instead. Specifically, I'm running this JL Audio 500/1 and 10W3v3 subwoofer together with the factory Lexus mids and highs and extremely happy with the result. It blends so well with the system and if you get a remote bass leveler (not bass boost control), you can control and fine tune the bass of each specific song. The bass is so damn tight, accurate, responsive and clean.
If you happen to live in Southern California, talk to Tommy@MusicBox because he is a audio pro! He recommended that upgrade and installed it for me.
Old 06-26-12, 03:05 PM
TrancEpimp
TrancEpimp's Avatar
KIM.. come check out my setup.. stock fronts/mids.. disconnected the factory sub.. replaced with 4080 stealthbox, , 12" JL w6v2, and JL 500/1 slash amp... perfect for SQL!
Old 06-26-12, 03:31 PM
kim0217
kim0217's Avatar
hey Mark, I really dont need that much bass, all I need is for the high pitch,cuz I always listen to Chinese songs
Old 06-26-12, 03:46 PM
FSportIS
FSportIS's Avatar
Seriously, the highs in Lexus system is more than enough. Adjust the treble boost to highest, turn the volume higher, those high can kill your ears in seconds.
Also, I listen to Chinese, Korean pop... too and the quality of Lexus factory mids and highs are adequate to handle those songs. Make sure your MP3 have high quality in the first place.
Old 06-26-12, 04:19 PM
Sffd103
Fire Slayer
Sffd103's Avatar
Kim, just listen to CD's cause those sound crisper and cleaner.
Quick Reply: Thinking about replace my OEM front and rear tweeters and speakers, need help!
