**VIS Carbon Fiber Hood
Old 06-23-12, 12:22 PM
NafisC
NafisC's Avatar
Default **VIS Carbon Fiber Hood
Just installed my new CF hood and I've gotten everything down, but I can't get the hood to close! It seems to not engage the latch fully and so it will not shut tight. Anyone else experience this? Any solutions? It seems on a part like a hood, there should be NO fitment issues whatsoever because every hood is the same. If it's a polyurethane lip I understand, but this isn't the case.
Would really appreciate if anyone knows what may be wrong. Only thread asking a similar question didn't receive an answer. Thanks.
Old 06-23-12, 03:28 PM
panda_ek9
panda_ek9's Avatar
All carbon fiber parts (even guaranteed perfect fitment) are not perfect fitment, I had the same problem with my seibon CF hood.. you gotta play with the latch on the car.. Goodluck
Old 06-23-12, 04:47 PM
Gville350
Gville350's Avatar
Are you sure you're slamming it closed hard enough? I already have to slam the OE aluminum hood, so I can only imagine what you might have to do to close a CF one. Try removing the rubber stoppers and see if that helps.
Old 06-23-12, 04:52 PM
whitebeast
whitebeast's Avatar
loosing all he bolts on the latch, pull it up and tighten it. If not work, you may need to enlarge the hold on the lack a bit so it could go up little more. Good Luck!!!!
Old 06-24-12, 08:10 AM
NafisC
NafisC's Avatar
The rubber stoppers that are under the first engine cover?
Old 06-24-12, 08:31 AM
NafisC
NafisC's Avatar
A hood SHOULD fit, every time. It's not made of fiberglass, or reinforced plastic with margins for error. It has 6 bolts to be held on, a company shouldn't be screwing up something that simple if I'm fat $$$ for it...
Old 06-24-12, 10:46 AM
Gville350
Gville350's Avatar
The two on the core support near the front driver and passenger sides.
Old 06-24-12, 03:49 PM
NafisC
NafisC's Avatar
Tried everything guys:/ removed rubber bump stops, and even pulled the latch up higher, yet nothing seems to work. I don't understand why this damn thing won't close
Old 06-24-12, 03:55 PM
uz07lex
uz07lex's Avatar
pics of it
Old 06-24-12, 03:57 PM
uz07lex
uz07lex's Avatar
when I close my cf hood I place it lightly then I push hard in the area of the latch. closes fine.
firelizard
08-25-16 07:08 AM
bigwes
06-06-12 10:03 AM
cm09578
IS F (2008-2014)
58
04-24-09 01:51 PM
mattyfast
01-09-07 10:05 AM
Quick Reply: **VIS Carbon Fiber Hood
