Rear Turn Signal LED Fix Decoder
#31
hey guys,
I replace 4 LED front signal... I bought a relay from V-LED... it work but your unlock/ lock light will not come on... V-LEd send a replacement but unfortunately it doesn't work again... I'm in the process of getting a resistor.. I think the resistor probably work a lot better then this decoder...
#32
I have no idea if they send a new revised one?.... but the second one they sent was even worst then the first one... the first one work lock/unlock but only driver blink.. passenger doesn't... I received a different one and this time ether driver or passenger blink..
#33
http://www.v-leds.com/Electronic-Fla...-p4957253.html
Make sure you tell them you want that one.
#35
I think you probably got the older one. The current one is in the link below; it looks most likely the same as you have but it's the inside which is different which addresses the issue.
#36
you don't need to tap w/ load resistor... the relay will do everything... I bought one from v-led and its doesn't work for me... work for others.. hopefully it will work for u.. good luck bro
#37
I wonder if it's the LED type you're using it's not making them work.
The resistor method is more of a guess because it's hard to measure how much draw they do since it's little. I would prefer this way myself since I don't prefer the first slightly long flash.
#38
I agree Sango, I notice the flash is slightly longer then the factory flash... the relay is so much easier and no tapping needed.. but I guess I have to go this route now... not that hard at all..
#39
Former Sponsor
These LED Decoders for the turn signals are perfect for some cars, but I'll be honest, they are not compatible with all cars.
Since these have slightly less resistance than the regular resistors, they may still cause the hyper-flashing issue or may not work with the vehicle at all. Some vehicles may also need two per side, just keep these in mind when purchasing it!
It seems like these work well for most Lexus vehicles though from what we've seen by selling it.
#43
Thank you iJDMTOY!!!
I just got this message from your company:
"Dear Customer,
Thank you for letting us know.
We went ahead and process the order for the 1 piece 8 pin relay to be shipped out to you please allow 1-2 business day for the order to process and ship out, please keep in mind if this does not work we will need you to send back the relay and the adapters for a refund.
For any questions or concerns, please feel free to contact us at anytime.
Sincerely,
Doc "
Great customer service....hopefully this works!!!
"Dear Customer,
Sincerely,
Doc "
