vled 6000k question?
Old 05-27-12, 02:40 PM
vboi4life
vboi4life's Avatar
Default vled 6000k question?
i have 6000k hid fog,parking light 6000k 4 flat led,6000k low beam ,vled drl module 6000k.the fuse for headlight highbeam fuse keep flewn,its 15am.i see a lot people run this setup in forum.why my fuse headlight high beam keep flewn.i was thinking change fuse to 20am or 25am.will it solve my problem?anyone know please help?Thanks
Old 05-27-12, 03:26 PM
my1s250
my1s250's Avatar
I gave up on mine...but mine keep blowing on one side only first it was the bulb then the module so now I just stuck with the regular bulb
Old 05-27-12, 08:25 PM
vboi4life
vboi4life's Avatar
my still work but just the fuse flew.i just replace second time and i will see when it gonna flew
Old 05-27-12, 10:59 PM
KillaIS250
KillaIS250's Avatar
You shouldn't ever change to a higher fuse to solve a lighting problem like that. They are rated what they are in the first place for a reason.
Might just be a faulty module?
Old 05-27-12, 11:15 PM
Sango
Sango's Avatar
Just to add on top of KillaIS250, yes true, and the wiring maybe only spec to rated a certain power which works with that system and fuse as intended. Using a higher one could lead to problems and the worse catatrophic cases, could result in an electrical fire.
Old 05-28-12, 10:00 AM
vboi4life
vboi4life's Avatar
its new model of module from vled.no flicking.it still work anytime i replace the new fuse.i dont think its module.
oespinoz
10-27-16 07:45 PM
SeanO
08-06-16 07:43 AM
redholm
RX - 1st Gen (1999-2003)
11-25-12 01:35 PM
R.G.
01-26-09 05:35 AM
BLAZE
01-07-08 09:12 PM
Quick Reply: vled 6000k question?
