Coolant over flowing and crusting. *pic*
Old 05-14-12, 10:09 AM
MiiK350
MiiK350's Avatar
Default Coolant over flowing and crusting. *pic*
I see this everytime I open my hood to check things out on my 350. I've seen this on my IS250 as well. Coolant levels are as recommended. Is this normal?
Old 05-14-12, 10:13 AM
weenstan
weenstan's Avatar
There was a TSB for this, I had mine done a few years ago.
Old 05-14-12, 10:28 AM
eggwoll
eggwoll's Avatar
Your water pump is probably going to go out soon.... happened to me
Old 05-14-12, 10:35 AM
MiiK350
MiiK350's Avatar
Sweeeeet info, sorry about repost!
Old 05-14-12, 11:30 AM
Hoovey689
Hoovey689's Avatar
This has happened to my car too before. around 20K miles
Old 05-14-12, 11:58 AM
edgeucated
edgeucated's Avatar
Im curious to know what cause this too.
This was happening to me until i bought in my car to have my water pump looked at. I had assume my water pump was going too but my SA told me my water pump was working fine; but I had them do a coolant leak check just to be sure. Ever since, I have had no coolant crusting.
Can you confirm this is the water pump going bad? because i have a pretty good relationship with my SA, i dont doubt him
Old 05-14-12, 12:08 PM
vangis350
vangis350's Avatar
I have the exact same problem with my 350.
Old 05-14-12, 12:24 PM
sthakor92
sthakor92's Avatar
Same problem! 250 with 12k miles
Old 05-14-12, 03:11 PM
eggtart
eggtart's Avatar
where can i find TSB for this. not in FAQ thread. does it affect certain model year.
Old 05-14-12, 03:35 PM
s6 4rings
s6 4rings's Avatar
Lexus of Tampa Bay said it is normal, and not to worry, had water pump replaced cause of a different issue. Bad bearing causing lots of noise.
Old 05-14-12, 06:08 PM
SD.IS
SD.IS's Avatar
I've been having this issue too.. Same question as everyone else I guess.
Old 05-14-12, 06:27 PM
heyarms
heyarms's Avatar
Have it too, never done anything about it either!
Old 05-14-12, 06:30 PM
chris07is
chris07is's Avatar
when i bought my car it was the same issue and took this to the dealer and they took care of it, and now its there again. it seems like its normal.. it took this picute on Oct 2007
Old 05-14-12, 06:33 PM
laobo979
laobo979's Avatar
Don't think it's the water pump. As the water pump is all the way toward the bottom. It leaks and wine that when you know it's bad. It cant spray up that high.
Old 05-14-12, 08:38 PM
mjh09e
mjh09e's Avatar
Mine does this too...2011 is350 w/ 18k miles
Quick Reply: Coolant over flowing and crusting. *pic*
