Problem changing drive belt
Old 05-01-12, 06:49 PM
TTechLexus
TTechLexus's Avatar
Post Problem changing drive belt
My IS has 100K and I decided to change the drive belt.
However, I tried loosing the tensioner bolt by turning it clockwise (left threaded) but it doesn't seem to be getting more loose. I then proceeded to pull upwards with a torque wrench and it won't budge.
Any ideas what I could be doing wrong.
I'm using the instructions by
chi 123
All you need is a breaker bar, a 21mm or 22mm socket (not sure but somewhere in the low 20's), new drive belt, and a helper. First, just take off the front engine bay cover and the engine cover. Put the socket and breaker bar on the tensioner bolt and pull up to the left to release tension (don't turn bolt unless it is completely tightened and you can't pull tensioner). Now have a helper take off the belt while you're pulling the tensioner. The install is just opposite, pull the tensioner and have another person put the belt in place. I forgot specifically, but I think it was easiest to slip the belt on the tensioner last. Then just release the tensioner and you're done. Tighten the tensioner bolt if necessary. (Here's where I messed up on, other kids in my Auto Tech class "loosened" the bolt by the "lefty loosey" method. I tried turning it right but it seemed to never stop, and the tensioner completely fell apart into the bay. That's when I found out the tensioner bolt is a reverse thread meaning you turn left to tighten and right to loosen.
https://www.clublexus.com/forums/per...-question.html
Old 05-01-12, 08:40 PM
chi123
chi123's Avatar
Might sound like a dumb question but are you sure you're trying to loosen the tensioner? I just went outside and checked right now using a serpentine belt wrench and right when I put the socket onto the bolt and pull upward, the belt comes loose.
http://www.autozone.com/autozone/acc...er=298547_0_0_
Old 05-01-12, 09:12 PM
TTechLexus
TTechLexus's Avatar
I bet I'm doing the wrong one
Could you point it out for me here please
Old 05-02-12, 09:00 AM
ULTiMaX99
ULTiMaX99's Avatar
the tensioner pulley is #2. if you're trying to replace the belt, you should be turning the bolt counter-clockwise/left. It takes a good amount of leverage/force, but the entire pulley should move left, allowing slack in the belt.
Old 05-02-12, 09:02 AM
B16da9
B16da9's Avatar
What this senor said , also if I were you draw a picture of how the belt is routed to make it easier to install the new one.
Old 05-02-12, 09:42 AM
mikellucci
mikellucci's Avatar
Yes, #2 COUNTER-clockwise as they said. My Camry is clockwise its easy to get confused.
Old 05-02-12, 10:32 AM
TTechLexus
TTechLexus's Avatar
Thank you all for your help!!
I feel like an idiot. I won't say which one I was pulling. haha
Old 05-04-12, 08:12 PM
GSteg
GSteg's Avatar
Number one?
Old 05-05-12, 10:42 PM
TTechLexus
TTechLexus's Avatar
Originally Posted by GSteg
Number one?
Old 05-05-12, 11:10 PM
Sango
Sango's Avatar
No no no!, it was #3! muahhaah
Old 05-06-12, 12:34 PM
CarbonDtls
CarbonDtls's Avatar
TTechLexus does that imply you're a Lexus Technician?
Old 05-07-12, 10:08 AM
TTechLexus
TTechLexus's Avatar
Originally Posted by PorSiempre
If you have to ask, you would be well advised to have the drive belt changed on your Lex to a professional.
Enough said.
No thanks, that's why I have this lovely forum where I can learn to do many things on my own.
Texas Tech Lexus
Old 05-07-12, 05:34 PM
2slow
2slow's Avatar
Was the belt cracked or frayed? Making noise?
If not, why bother changing it?
Old 05-07-12, 05:37 PM
MikeyK02
MikeyK02's Avatar
Texas Tech Lexus
Buzz....
your cheerleaders....
WOOF!
Old 05-07-12, 05:47 PM
TTechLexus
TTechLexus's Avatar
Neither but it had 100K miles and I was already in the bay changing spark plugs and other stuff so it's just preventive maintenance.
It was only $27 from Sewell
xshurikx
SC- 1st Gen (1992-2000)
12-22-13 10:05 AM
G430
08-07-13 05:24 PM
mikes7ke
03-02-12 01:03 AM
need2boost
05-07-10 08:03 PM
TJohnson
Performance & Maintenance
01-17-08 02:31 PM
Quick Reply: Problem changing drive belt
