Finished 2012 LED Headlights Retrofit
#46
I had DDM tuning bulbs... What a load of crap compared to the output of Phillips 85122+ or osram CBI's.
The 85122+ are less expensive then the CBI's and if you're ok with the 4300k look I say totally go for those cause of the price
If you like 5000k but want the same great output of the phillips 85122+ then go CBI's. It just takes about 20-25 hours before they turn 5000k
If you decide to go CBI's, PM me. I have a hook up over on the hid planet forums.
Sorry for derailing your thread a little.
Back on topic to for the OP
#47
O yea I totally agree with you then
I have morimoto 5000k and they're decent. I want oem but the only thing holding me back was the bulb temp. I may hit you up on that soon!
#52
Another great retrofit! Well done! You should change out those amber turn signal bulbs for the chrome bulbs. Well that's just what I'd do. Again, amazing work! I used your bracket system on the 06-10 headlights, I may have to hit you up for this if I pull the trigger! Haha
#53
Another great retrofit! Well done! You should change out those amber turn signal bulbs for the chrome bulbs. Well that's just what I'd do. Again, amazing work! I used your bracket system on the 06-10 headlights, I may have to hit you up for this if I pull the trigger! Hah]
#57
Thanks, I put about 50 hours into the project.
#60
Just like my last retrofit I have not pluged it up with anything and I have not had any issues with condensation. The key to this is to make sure you seal the lence correctly. You will also notice that I covered the holes where the factory ballast would mount as I'm running Nissan ballast on my car.
