DIY: 2011+ MY LED Headlight Installation ("How To")
Old 04-25-12, 08:26 AM
cyberscorp
cyberscorp's Avatar
Default DIY: 2011+ MY LED Headlight Installation ("How To")
* * * USE AT YOUR OWN RISK * * *
"I'm not a Mechanic or Auto Body Specialist. I sit in-front of my computer all day at work. That being said; If I can do this Step-By-Step DIY, so can you!" . . . JD
ITEM TO INSTALL:
2012MY LED HEADLAMP RETRO-KIT "Loaded" (Sewell Parts)
RECOMMENDED MATERIALS/TOOLS:
4 x Wheel Chocks (Walmart)
In-Car Scissors Jack (Applies to Lowered Cars)
Jack (I used Michelin 3½-ton Speedy Lift Jack @ Canadian Tire)
2 x 2-Ton Axle Stands (Walmart)
Old Carpet Runner or Old Exercise Mat (for Bumper Protection & Back Support)
Automotive Work Gloves (Canadian Tire)
Zip Lock Plastic Bags (for clips & bolts @ No Frills)
Phillips Screwdriver (Canadian Tire)
Jeweler's Screwdriver (Canadian Tire)
Socket Wrench with 10mm Socket + Extension (Mastercraft @ Canadian Tire)
Painter's Tape (for Fender Protection @ Canadian Tire)
Rotary/Cutting Tool (Rona)
Safety Glasses (for Eye Protection @ Canadian Tire)
Flash Light (for Relay Flasher @ Canadian Tire)
Long Nose Pliers (for Relay Flasher @ Canadian Tire)
OPTIONAL:
62mm Audio/Video Dash Removal Tool (for stubborn clips @ Ebay Motors)
170mm Audio/Video Dash Removal Tool (for Plastic Fender Cover @ Ebay Motors)
STEP 1
1.1) Press Engine START/STOP
1.2) Make note of the ODOMETER Reading and Date of Install (This helps me keep track of my MODS)
STEP 2
Place "Wheel Chocks" in front of and behind the rear wheels and wedge them securely against the tires.
The following 2 users liked this post by cyberscorp:
Isfast (01-08-17), sede7 (03-25-23)
Old 04-25-12, 08:27 AM
cyberscorp
cyberscorp's Avatar
STEP 3 (OPTIONAL)
3.1) Hoist the vehicle by using Lift Jack. I used the In-Car Scissors Jack (applies to lowered Set-up) . . .
NOTE: I lifted the vehicle to gain access easily to bolts underneath. This method is not necessary for vehicle with enough clearance to reach bolts/screws. However, It's a must for lowered cars.
Note: Front/Center Jack Point
3.2) . . . Place "3½-ton Speedy Lift Jack" underneath the car.
STEP 4
Place the "2-Ton Axle Stands" to the Driver & Passenger Front/Side Jack Points
STEP 5
Pull the hood release lever.
STEP 6
Carefully remove the Plastic Covers. There are 16 Plastic Push-In Clips (Red Arrow) and 2 Plastic Bolt (Yellow Arrow).
Push-In Clip in the middle
Top Left/Passenger Side Plastic Bolt (Close-up). Same bolt on the Top Right/Driver Side.
Use Phillips Screwdriver for this Plastic Bolt (Gently, this bolt is sensitive)
STEP 7
Keep all "Push-In Clips" (+Bolts/Screws) together in Zip Lock bag. It will help you when putting the parts back . . .
Perfect time to clean Dusty areas . . .
STEP 8
Front Bumper: More Bolts & Clips. 2 x cross head plastic screws, 2 x metal cross head screws with rubber housing, 4 x clips & 1 x 10mm bolt.
Use Phillips Screwdriver. 1 x cross head clip & 1 x cross head screw with rubber housing (Left/Passenger Side)
Use Jeweler's Screwdriver. 2 x Plastic Clips (Left/Passenger Side)
Use Wrench with 10mm Socket. 1 x 10mm bolt (center)
Same Tools apply to Driver Side. 1 x cross head clip & 1 x cross head screw with rubber housing. 2 x Plastic Clips.
sede7 (03-25-23)
cyberscorp
cyberscorp's Avatar
STEP 9
9.1) Place Old Carpet Runner to Protect Bumper from floor debris
9.2) Start Engine, Turn Steering Wheel to the Right (to gain access to Plastic Wheel Well).
2 x clips, 4 x 10mm bolts
Work Gloves
9.3) Use Jeweler's Screwdriver (2 x Plastic Clips)
9.4) Use Wrench with 10mm Socket
TIP: I used 170mm Audio/Video Dash Removal Tool to expose the hidden 10mm bolt.
9.5) Use Phillips Screwdriver for 3 x bolts attached to the Engine Under Cover
Same method applies to the Passenger Side:
1) Start Engine, Turn Steering Wheel to the Left.
2) Remove 2 x Plastic Clips
3) Remove 1 x 10mm bolt
4) Remove 3 x 10mm bolt/screws
STEP 10
Remove 6 x 10mm bolts.
NOTE: Use Masking Tape to Protect Fender/Headlight from accidental scratches
STEP 11
Lift the Negative Battery Cover and start loosening the bolt using 10mm socket wrench.
STEP 12
Gently pull the Bumper Off.
NOTE: You will need an assistant to help you with the Bumper Removal
Disconnect/Unplug Fog Lights
1 x connector - Passenger Side (Press Pull-down method)
2 x connector - Driver Side
Remove Front Bumper
STEP 13
Headlights: Remove 3 x 10mm bolts with Socket Wrench.
10mm Socket Wrench with Extension
NOTE: 2 x 10mm bolts are same size (top), 1 x 10mm bolt-longer (side)
sede7 (03-25-23)
Old 04-25-12, 08:28 AM
cyberscorp
cyberscorp's Avatar
STEP 14
Unclip then Unplug Headlight Wire Connector.
STEP 15
Gently pull Plastic Cover (as shown below).
Unlock Headlight Clip (as shown below).
STEP 16
Headlight Bracket.
Remove 3 screws with Phillips Screwdriver
STEP 17
NOTE: You will need to custom fit the existing Bracket before transferring to the New "2012MY LED Headlights".
I use Dremel 4000 to get the job done.
Don't forget to wear your Safety Glasses
. . . Test Fit+Cut, Test Fit+Cut, Test Fit+Cut; till it line-up properly (I did this 3 x the first time).
NOTE: ONLY 2 SCREWS WILL HOLD THE BRACKET
Same method applies to the Driver Side Headlight:
1) Remove 3 x 10mm bolts
2) Unplug Wire Connector
3) Unlock Headlight Clip
4) Remove 3 x Screws from Bracket
5) Custom Fit/Cut Bracket
STEP 18
Install Relay Flasher
18.1) Remove 2 cross head screws with Phillips Screwdriver.
18.2) Slide Carefully
Flash Light Required
18.3) Place Old Towel (or similar) to protect Side from Scratches (My Work Jeans has small metal bottons) . . .
18.4) To remove the existing "Flasher Relay (Green)", use long nose pliers.
(TIP: Press to Unlock)
Install new Flasher Relay 81980-06020 (Brown)
1) Attached to Connecting Wire
2) Re-attach to place-holder
18.5) Check the Signal
. . . at this point, you're ready to Install the "2012MY LED Headlight".
1) Attach the Custom Cut Bracket to "2012MY LED Headlight" (Passenger)
2) Re-install 3 x 10mm bolts (Longer Bolt goes to the sides)
3) Plug Headlight Wire-Connector
4) Same steps above applies to Driver Side.
STEP 19
Test all Light Settings before Installing Front Bumper.
Once satisfied; install parts in reverse order . . .
MrHarris (05-17-22), sede7 (03-25-23)
cyberscorp
cyberscorp's Avatar
COMPARISON PICS
Old 04-25-12, 08:39 AM
flyfl1pguy
Registered User
flyfl1pguy's Avatar
AWESOME job!
Old 04-25-12, 08:42 AM
swirvin
swirvin's Avatar
Nice write up! I will use when I purchase my 2012 headlights.
Old 04-25-12, 08:51 AM
Rash
hmm
Rash's Avatar
Great write up! added to the FAQ, thank you!
Old 04-25-12, 09:45 AM
Gustavo250
Gustavo250's Avatar
Awesome write up Name:  AnimatedBravoSmiley.gif
Old 04-25-12, 10:07 AM
po1qw
po1qw's Avatar
beautiful write up and good picture guides
Old 04-25-12, 10:17 AM
MikeyK02
MikeyK02's Avatar
Full of win...awesome DIY
Old 04-25-12, 11:35 AM
neomedic
neomedic's Avatar
If every write-up was like this.....autoshops and mechanics would be out of business!!!
Good Job!!!!!!!!!!!!
Old 04-25-12, 02:59 PM
patbateman
patbateman's Avatar
This is one of the most detailed DIY guide I've seen on here! GREAT JOB!
Old 04-25-12, 03:02 PM
KillaIS250
KillaIS250's Avatar
Damn that is one super detailed write up. Thanks for posting it on CL. Sure it will help out a lot of people!
MrHarris (05-17-22)
Old 04-25-12, 04:00 PM
F Monster
F Monster's Avatar
I don't even own an ISX50 yet and I already know this guide is going to be super useful in the future for me. :P
Quick Reply: DIY: 2011+ MY LED Headlight Installation ("How To")
