Fog lights dont work since dash swap
So I swapped my dash and everything went flawless, but I noticed that my foglights don't work. I checked all the fuses and it's either I forgot to plug something in or the HID kit for the foglights blew out on both sides without popping a fuse...
Question is where could I have missed plugging in a wire under the dash? Reaching out to the Clublexus community for help
I know it's one of these wires lol
I would check the wiring on the stalk for your headlights (left of steering wheel). I'm just guessing that there's a wire there dedicated to sending a signal to the fog lights when switched on/off.
Also, do your DRL's and high beams work properly?
I believe there are two inside the car. One on the passenger side, and one on the drivers side under the dash.
Here's a link to the owners manual with fuse box diagrams a locations--> http://drivers.lexus.com/t3Portal/do.../sec_04_03.pdf
I believe the fuse for the fog lights is located in the engine compartment fuse box, not inside the car.
I would try testing the wires and see where you are losing power along the way. Start at the stalk and work your way through the wiring harness down to the fogs. Might be a lot of work, but it's worth a shot to see where you are losing power.
Never mind, I followed this foglight mod and wired them to come on when my parking lights come on and voila!
https://www.clublexus.com/forums/is-...dlights-2.html
Topshottaz
07-15-12 03:34 AM
