Manual Transmission TSB
Old 03-22-12, 09:36 AM
iTaLiAnO
iTaLiAnO's Avatar
Originally Posted by Sffd103
I'm wondering if I could get this done...
if its making noise, and u still have powertrain warranty left...
Old 03-23-12, 07:55 AM
GoingBig
GoingBig's Avatar
someone get this done and let me know what happens! lol
Old 03-23-12, 08:04 AM
plmeeker
plmeeker's Avatar
here is a copy of the TSB...
© 2011 Lexus, a division of Toyota Motor Sales, USA
Page 1 of 2
L-SB-0059-11 July 28, 2011 Page 2 of 2
Abnormal Noise when Releasing Clutch in Gear (6 Speed MTM)
Required Tools & Equipment
REQUIRED MATERIAL QUANTITY
API GL5 75W-90 As Needed
Repair Procedure
1. Test drive the vehicle and confirm there is a squeak or grinding noise from the transmission
assembly when releasing the clutch in gear.
See attached video for an example of this noise:
Transmission Squeak or Grinding Noise
If a squeak or grinding noise is present, replace the clutch disc and transmission.
NOTE
To correct this condition the transmission and clutch disc must be replaced together.
Refer to the Technical Information System (TIS), applicable model and model year RepairManual:
• 2006 IS 250:
Drivetrain – Clutch – “Clutch: Clutch Unit: Removal / Installation”
• 2007 IS 250:
• 2008 IS 250:
• 2009 IS 250:
• 2010 IS 250:
• 2011 IS 250:
• 2010 IS 250C:
• 2011 IS 250C:
2. Confirm the repair.
Old 03-24-12, 12:04 PM
busdepot
busdepot's Avatar
Originally Posted by Jeff Lange
All 06-12 models have an unsprung clutch. They use a dual-mass flywheel instead. It's not rough.
All 06-11 IS250 MT's quality, possibly even 12's.
All 06-12 models have an unsprung clutch. After the TSB, it would have a sprung disc.
Correct, your dealer will need to confirm the noise.
Jeff
Jeff, is this campaign available in Canada, specifically in Calgary?
Old 03-26-12, 07:03 AM
jcampana
jcampana's Avatar
Default Any videos?
Does anyone have a video of what this sounds like? I just bought an 08 MT IS 250, and hear a noise every once and a while while shifting that I'm having a hard time describing to my mechanic. He looked at the car and didn't find any problems, but I'm still hearing it.
Thanks!
Old 03-26-12, 07:42 AM
B16da9
B16da9's Avatar
I had this done to my car about 2 months ago and I can tell you that on my 07 it was night and day. The shifting is a lot more precise (feels almost like my Integra). Also the clutch pedal is a lot softer (I actually prefer the harder pedal of the un-sprung disk) but I can live with it.
For those of you that want to have this done just tell your dealer that you get strange noises coming from the Gearbox while shifting and they’ll look into it. Also make sure you tell the service advisor your can is a manual transmission (mine assumed mine was automatic) so they write up the service ticket correctly.
Once they find the noise be prepared to wait about two weeks to get your car back as they’ll have to special order the gearbox and clutch/pressure plate as it is not a part that is kept in stock.
Old 03-26-12, 08:46 AM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
The pressure plate isn't replaced, so pedal pressure shouldn't have changed, unless your throwout bearing wasn't moving as easily as it should have, which could affect pedal feel.
Jeff
Old 03-26-12, 08:48 AM
B16da9
B16da9's Avatar
Jeff
My work order has the clutch disk and pressure plate, not sure about the throwout bearing but I'll double check when I get home.
Old 03-29-12, 10:01 AM
Moekind
Moekind's Avatar
Does anyone have the Canadian copy of the TSB?
Old 04-04-12, 01:47 AM
GoingBig
GoingBig's Avatar
did you guys go to lexus and get this done yet? How did it go? I'm planning to take mine in soon :]
Old 04-18-12, 08:58 AM
jcampana
jcampana's Avatar
I'm taking my 08 in for this on Thursday. We'll see if they hear the sound and if they replace it. Not looking forward to not having my car for 2 weeks. I know I'll get a loaner car that will be newer, but I got my car as a stick for a reason! I'll let you all know how it goes
Old 04-18-12, 10:46 AM
GoingBig
GoingBig's Avatar
tell us how it goes after! lol
Old 04-25-12, 10:15 AM
Moto
Moto's Avatar
Went to the dealership to get a couple recalls taken care of and also had them take a look at this issue. According to the TSIB that Lexus sent out, every car that has this issue will be covered IF your car is under 70,000 miles and is under 6 years old from it's original manufacture date.
So if anyone on here is wanting to get this taken care of and getting close to either of those I'd suggest you get it done asap!
Old 04-25-12, 11:01 AM
B16da9
B16da9's Avatar
Well I'm happy to report that after having this done to my car she still feels better than when I first bought her. Now I'm just waiting for my powertrain warranty to expire before I install my Findanza Flywheel.
Old 04-29-12, 07:16 PM
afx588
afx588's Avatar
I have an 08 MT IS250 and I'm hearing the "jar of marbles" sound, especially in stop and go conditions (or as the car warms up). Is this something totally different from the "squeak or grinding noise" mentioned in the TSB? I'm at 56K miles so I'd like to get this done if possible.
Also, anybody have videos of the sound yet?
Quick Reply: Manual Transmission TSB
