50K and just getting started: A list of everything replaced so far.
Hey guys and gals.... Just hit 50K this weekend. I am looking forward to another 50. Here is a list of things that I have replaced since the begining.
1. Tire Pressure Sensor (under warrenty)
2. Waterpump (under warrenty)
3. Dash Rattle TSB (under warrenty)
I ALWAYS keep up to date on my maintanance. I plan on doing Brake Pads this summer so I will let you know how worn those are. Love the car and I dont think the next 50K will be much different. I also run a bottle of Techron through a tank of gas the tank before I change the oil... to date I have had no real problems.
Others with 50K what problems have you had so far?
Previous owner :
-fuel tube replaced by dealership
-A/C in-cabin leak...carpet replaced by dealership
-water pump replaced by dealership
-spring recall, done by dealership
Me :
-Fuel sensor recall
-Master cylinder "cup" recall
-Tires
-Front brakes
-Front rotors
-Shocks/springs...replaced with BCRs, my choice obviously
Other than the TSIBs, recalls, and usual preventative maintenance I've had zero complaints with my '06 350!
Me :
-Fuel sensor recall
-Tires
-Front brakes
-Front rotors
Currently @ 45k
Maintenance:
LOF every 5k
Repair burnt fog light connectors due to Nokya 2500k bulbs @ 10k
Filters and wipers every 15k
Brake fluid flush @ 30k
2 tire patch repairs
2 sets of tires
A few four wheel alignments
Front brake pads and machined rotors @ 25k
Warranty:
Recalls
Seat squeak TSIB @ 12K
Adjust parking brake @ 29k
Battery corrosion cleaning @ 45k
Maintenance:
LOF every 5k
2 sets of tires
Warranty:
Recalls
Im under 50k and every thing ive done has been a recall or warranty except:
Brakes at 30k or so + two front rotors
This is technically my 2nd set of tires however Ive had temporary tires from wheels I was just testing for about 5k each twice so subtract about 10k of miles.
No complaints
No complaints
If your bulbs are a higher wattage than the factory lights, you run the risk of burning the OEM wires. You see this a lot with Honda's and stuff where they run 100w lights in 35-55w connectors As long as the bulbs you replace your OEM's with are at or below what the factory bulbs are, you shouldn't have any issues though.
I've replaced the HID headlight bulbs and the battery. Other than that, the usual stuff - wiper blades, filters, oil. Oh yeah, just did the spark plugs at 61k. Piece of cake. Brakes pads next. I love how easy this car is to work on (thanks to this forum of course! )
Hmm, I just had my Waterpump done..... It seems that it NEVER gets up to the 1/2 way point like it use to.... I think there is a bad angle in the photo. I think the new fluid keeps it cooler then it was at 40K miles.
HS805
05-15-19 11:55 AM
