Non Flyaudio Navigation system - center vents fitment.
#31
M88JCP, can you post a pic of what you mean by stick out?
My car is in for some work so wont be near it in the next week or so.
Fitting the vents was straight forward for me.
Are you sure nothings blocking, interfering with the vents from the back, extra wiring etc? I know mine needed to be pulled to move the led wiring so it doesnt interfere and then it was all good.
#32
#33
M88JCP I had a little bit of trouble also with what you are talking about, I found that the wires behind the unit caused my nav to stick out just enough, even though I tightened all the bolts as much as I could. So what I did was took the unit out and when sliding the nav system in I held all the cables above the unit so they would'nt get in the way. Not sure if that will help you or you have tried that, but for me that fixed the problem.
#35
IamNate, thanks for the help. I tried that and it didn't help. I've now fixed the problem, I had to remove a couple of the tongs on the back of the unit and now it fits perfect.
KrUnIzze, I brought my unit from a company on Alibaba Express - LSQ Shenzen. It was about $520 inc postage.
#36
Hi,
Looks the same on my end M88JCP but maybe a bit less of a gap in the midle between vents and unit. will have to take another look.
IamNate - will try to get what you asked for today.
#38
I guess it would be this one
http://www.aliexpress.com/store/prod...555243459.html
Since i have a 2008 IS250.
And If You Scroll Down It Says "LSQSTAR -CAR DVD PLAYER LEXUS IS250 (2008-2011)" in purple.
#41
I e-mailed the company direct re my unit, address documented below.
<sales3@lsqbusiness.com>
Hope it helps
Johnchi, I managed to get my unit to fit like stock, no overlay and it doesn't stick out on the sides. However I did have to take a saw to some of my tabs on the back
Hope it helps
#42
Hope it helps
Hope it helps
