Non Flyaudio Navigation system - center vents fitment.
Hi,
So got the 09-11 center vents delivered and installed them.
The gap is gone and fitment is as expected - just like stock.
The only thing to note is this. The oe 07-09 vents have two connectors for lighting up the flap dials. The 09- have one connector. The connectors need to slightly be modified. By clipping off some plastic. You will see what I mean and its a w minute modification.
Now I am happy with the setup. Pics later on.
Updates are available but takes chinese skills which I don't have to find them. My friend that ordered the unit for us got the latest is250 version for me and it installed just fine. Didn't reaally notice any diff so its still good for now.
Follow Up
Any follow up info you can provide about this unit since you've had a few months with it now? Any support or reliability issues? Have you received any firmware updates that address the quirks you noted earlier? Is it worth the investment?
The unit still works.
as for some of the issues noted above.
Radio - Bad
Intermittently the channels will switch their assigned slots after car if started maybe once every 2 - 3 days. manageable? yes annoying? yes
Update - once all slots were populated with a radio channel this stopped happening.
Ipod - Bad
Sometimes I will only get sound in the front right speaker.
update: changed cable all is good.
CD playback - Bad
Sometimes when selecting CD playback it will default to aux. This also means if your listening to a CD with the navigation on , after navigation gives directions it will revert back to AUX instead of CD.
Once I disconnected the aux cable from the aux port - this doesnt happen anymore so while not perfect its not an issue.
Radio - Bad
Ipod - Bad
CD playback - Bad
Hi Johnchi
How did you manage to fit the new style airvents? I have just tried to fit them along with this unit (good writeup thankyou) and they do not want to fit on the bottom. They just stick out!!
Thanks
Thanks
Hi,
