Need help [trouble resetting window after battery disconnect]
Guys, I need help with my 07 is350. Last week I changed the battery of the car and I did my window RESETING.. But my passenger front window will not work it won't go up or down from either switch and the light itself of the switch keeps blinking. What can it be?
Thanks
Thanks
That's the problem it won't do anything. I cant take it down or up. All the other windows are fine except for that one. And the passenger switch light is just blinking at all times.
Super Moderator
Just to clarify, you are trying to roll it down from the switch on the passenger door, not the cluster of switches on the driver door, right? Did you check to make sure the child-lock switch is off?
carlos3366
02-04-15 11:08 AM
