Emblem/Badge removal
Old 01-27-12, 03:11 AM
LostS0ck
LostS0ck's Avatar
Default Emblem/Badge removal
Want to remove Both my Lexus emblems front and back and the IS250 badge to paint it. The best way is to use fishing line and goo gone right ? As for the IS250 badge are all the letter and numbers separate pieces ? What do I use to the emblems back ?
Does it look like this ?
Old 01-27-12, 07:48 AM
bob4256
bob4256's Avatar
If I remember correctly, the I and S are stuck together and the 2, 5, and 0 are as well. And yes goo gone and a fishing line are the easiest way to do it. Why not just plasti dip the emblems while theyre still on your car? Its easier to do IMO
Old 01-27-12, 10:18 AM
shadowman
shadowman's Avatar
Heat it up a bit to make it easier... you can park outside on a hot sunny day or use a hair dryer.
Fishing line to slice thru it and goo gone to remove the left over residue.
To put the emblems back, use 3m double-side tape. Make sure to choose the thin strip so it doesn't bulge too much.
If you're planning to paint it, you can try to plastidip it as bob4256 said. It's much easier because you don't have to remove the emblems and re-attaching it when done.
Old 01-27-12, 11:03 AM
GiantsFan
GiantsFan's Avatar
Also,
Use painters tape to tape around the emblems so you have a nice guide for when you put it back..
codenko
codenko's Avatar
Just use plastidip and dont take em off at all...worked really well for me
Old 01-27-12, 01:39 PM
LostS0ck
LostS0ck's Avatar
I wanted to paint it another colour other than black.
Anyone tried the Plasti dip create your own color ?
Old 01-27-12, 07:46 PM
bob4256
bob4256's Avatar
I thought they only sold black and red plasti dip?
Old 01-27-12, 07:52 PM
LostS0ck
LostS0ck's Avatar
They got this one.
http://www.acehardware.com/product/i...Id=54648188404
Idk, how im going to put it on though.
Old 01-27-12, 10:41 PM
Jzsicklexi
Jzsicklexi's Avatar
I just pulled off my emblems with heat, taped screw driver head, and fishing line. Worked awesome. All of the is250 letters are seperated.
Old 07-12-12, 05:33 PM
dci4life
dci4life's Avatar
A tip you can do and what I did. As long as you plasti-dip before. You can spray paint it what ever you want. I did mine in blue. It looks good IMO. And yes if you ever want it off. You can rub your fingers on it and rub it off just like plasti-dip. I'm doing my wheels a funky color here shortly. Just cause if I don't like it. I can peel it off.
Old 07-12-12, 09:41 PM
G85
G85's Avatar
^ I thought spray paint will ruin plasti dip???
Has anyone else done this before?
Old 07-13-12, 05:38 AM
heyarms
heyarms's Avatar
All letters and numbers are individual pieces, as the OP picture shows.
I'm all for NOT plasti-dipping... Paint them the right way.
Old 07-18-12, 10:45 PM
lexusMnl
lexusMnl's Avatar
use FLOSS and run it behind the emblem
Old 07-19-12, 07:42 AM
linus73
linus73's Avatar
i removed alll my emblems too. i just used a plastic flat radio panel tool., i got all the emblems off in less than 30 seconds. then i cut out some black vinyl circles to go over the tiny holes that were left behind, from a distance you could not tell there are holes.
Old 10-19-18, 09:38 AM
Brandonk1
Brandonk1's Avatar
Just buy "duplicolor custom wrap" it looks way better than plastidip imo
mxis350
04-16-14 11:24 AM
hoosier58
SC- 1st Gen (1992-2000)
19
09-18-13 05:39 PM
javila32
12
06-02-09 04:32 PM
ssmoked
10-01-08 09:43 AM
blkbeauty
07-09-05 10:51 AM
Quick Reply: Emblem/Badge removal
