Remove passenger side speaker grille
Old 01-08-12, 11:05 AM
guini2000
guini2000's Avatar
Default Remove passenger side speaker grille
How do you remove passenger side speaker grille/cover??
Old 01-08-12, 11:42 AM
irishcharm
irishcharm's Avatar
you remove the whole door panel............also specify which speaker grill. there are 3. - see DIY in the audio section
Old 01-08-12, 02:01 PM
Sffd103
Fire Slayer
Sffd103's Avatar
here are pics removed. Not specifically how to remove. https://www.clublexus.com/forums/lex...with-pics.html
Old 01-10-12, 06:22 AM
irishcharm
irishcharm's Avatar
there are tons of DIY's on this. but in text form.
pry up your window switch panel....remove a screw behind it.
with a pick hook, remove the plastic piece behind the door handle interior (where the lock is) - remove a screw behind it.
rest of the door is held in by pop clips so pull gently yet with some force and then start disconnecting the things behind the door.
GL
orionshoot
05-31-18 01:00 PM
RushNatU
03-11-14 03:24 AM
Goofaroo
02-08-12 02:01 PM
johnny_d
06-01-07 10:49 AM
EScraig
03-25-02 10:51 AM
Quick Reply: Remove passenger side speaker grille
