Frozen Navigation Screen Fix DIY
Old 07-11-16, 12:37 AM
  #436
MrWizard
MrWizard's Avatar
I used this one and have been happy with the results.
NIUTOP 7.3'' Inch Touch Screen Digitizer (No LCD Screen Display) Panel Replacement Repair Part Fix for Lexus Is300 Is250 Is350 (For Car Navigation 2006-2009 Years Only) https://www.amazon.com/dp/B00H3DMCJ4/ref=cm_sw_r_cp_api_DX0GxbWERRX9Q
Old 08-24-16, 06:20 PM
  #437
dragonphp
dragonphp's Avatar
I finally got around to fixing mine about 2 weeks ago. If you know how to use a screw driver and a small torque wrench, it should be fairly straight forward. I opted to purchase a new digitizer ($50) instead of putzing around with that silly circuit writer.
I bought a digitizer from this guy: http://www.ebay.com/itm/331555180866?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Check out my video:
Old 10-15-16, 02:53 PM
  #438
playlaguna
playlaguna's Avatar
Anyone available to help with this problem in OC/SoCal? Not really a do it your-selfer as I usually create more problems than I solve.
Thank you
Old 10-16-16, 10:51 AM
  #439
whitebeast
whitebeast's Avatar
Check your PM.
Old 10-16-16, 08:04 PM
  #440
lonestr250
lonestr250's Avatar
Nice write up
Old 10-23-16, 09:45 PM
  #441
playlaguna
playlaguna's Avatar
Thank you. Whitebeast.
Problem solved quickly and reasonably.
Old 10-24-16, 06:41 AM
  #442
whitebeast
whitebeast's Avatar
Not a problem at all!!!
Old 11-16-16, 08:59 AM
  #443
Premier
Premier's Avatar
Anyone in NJ/Nyc that can help with this, for a fee of course
Old 11-25-16, 01:26 PM
  #444
Fausty
Fausty's Avatar
I bought a digitizer from this guy: Navigation Touchscreen Digitizer Glass 2006 2009 Lexus Is GS Toyota Prius Models eBay
Check out my video:
How to Fix a Frozen Screen on a Lexus IS (2006-2013 Models) - YouTube
my screen isn't responsive on my gs460. Will this work for me too? Can I order a digitizer? Any feedback is appreciated as almost all post are for the is.
Old 11-25-16, 10:02 PM
  #445
whitebeast
whitebeast's Avatar
What year of your car so i could check the connector for you
Old 11-25-16, 10:05 PM
  #446
whitebeast
whitebeast's Avatar
2008 gs460 using same connector with is touch panel but the ribbon cable is little longer than IS. Really sure the after market touch panel ribbon cable is long enough for both car (universal connector)
Old 11-26-16, 08:19 AM
  #447
Fausty
Fausty's Avatar
so you think I should be ok with the one used in the vid above? I didn't know the gs had the same issue. I think mine might have gone due to the car sitting in the Miami sun for a week while I was out of town. Sucks big time but I'm glad I found this thread.
Old 11-27-16, 12:16 PM
  #448
whitebeast
whitebeast's Avatar
I never use any after market part so i couldn't tell you the quality of it. As for cable, it's work fine!!!
Old 11-27-16, 03:30 PM
  #449
Fausty
Fausty's Avatar
Anyone in south Florida willing to install one for a fee? Please pm me.
Old 11-28-16, 09:39 AM
  #450
Mr2KiEu
Mr2KiEu's Avatar
The digitizer from the eBay link and video works perfect with your 2008 GS460. The ribbon cable is longer and thinner than the OEM, but it still works because it has the 4 pin connector ribbon. Lexus uses the same digitizer for certain year model IS, GS, RX, and Prius.
Quick Reply: Frozen Navigation Screen Fix DIY
