Frozen Navigation Screen Fix DIY
#421
I just replaced the digitizer. I didn't look at the brand of the screen. The replacement digitizer is suposed to be a toshiba.Attachment 381697
Now it looks like this. Not good
#422
Digitizer
Thanks for info Mr2kiEu!! Lots of work to install a new screen and have it look like this.
Where do you find the digitizer with the clear black glass?
Thanks
Thanks
#423
Digitizer resistance reading
I just got the digitzer from German Audio Tech, got fooled by their cheating add (they say it is new and it is toshiba, but after seeing this screen) i am sure it is not new nor toshiba.
I just measured the resistance for the pins, and did not match those listed:
"The resistance between pins 1 and 3, and 2 and 4 should be about 500 and 1700 ohms." mine are half those values.
Should i proceed and uninstall the dash, or should i return this digitizer and get a new one from somewhere else? will it work?
#424
Update!!
Over the weekend I pulled the navigation unit out of the car. I was told there could be a black screen protector on the digitizer that can cause the rainbow effect on your screen. After closely inspecting the digitizer, there was a screen protector on it. I used the tip of an exato knife and gently lifted it up in one corner and removed it. I reinstalled everything into the car.
Now the navigation looks like new. The touch screen works great again!!!
#425
Hey guys,
In my haste (and laziness), instead of getting pliers to properly unseat a connector from the screen to its electronics, I pulled too hard on the actual wires and pulled all the conductors out of the connector. Being my luck, this also happens to be a connector with 5 holes, but there are only four conductors. Can somebody please tell me which color conductors go in which holes? Thanks so much for your help.
(in the second image, it'd be the beige connector that is just to the right of the lefthand screw. Even examining the leads on the PCB doesn't give me enough information)
#426
Hey guys,
Attachment 383714
Attachment 383715
Attachment 383714
Attachment 383715
#427
Hey guys,
Attachment 383714
Attachment 383715
Attachment 383714
Attachment 383715
#428
#431
can't decide whether to do this repair myself or not. i only use the nav screen to watch movies but i'm pretty sure when i go to resell the car, the next person will want to operate the nav, bluetooth, etc....none of which i use. if i could pay someone to do this, i would consider driving a reasonable distance from KS.
#434
Hello Clublexus members,
I have an excellent condition navigation unit for sale, please look if interested thanks! --> https://www.clublexus.com/forums/is-...reen-unit.html
#435
Everyone should purchase their screen from this link
http://www.ebay.com/itm/Touch-Screen...-/331555180866
Just installed it and everything works great, no rainbow effect and very helpful seller who is a clublexus member as well.
Good luck!
Good luck!
