Lexus IS Can I use the CD changer to play movies?
Old 02-16-17, 10:04 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
I had wondered whether it would work, as despite the digital outputs, they do still have the others as well. Interesting to get confirmation.
Jeff
Old 02-17-17, 02:50 PM
istarzan
istarzan's Avatar
I swear I saw a post that someone did it. Replaced CD player with DVD mark levinson. Don't think it was on club Lexus. Maybe my.is. It was like 5 years ago tho. I'm gonna try this if I can secure a used DVD unit.
Old 02-19-17, 03:22 AM
See5
See5's Avatar
Yes you can with ML,
I went further and made a DVD containing video clips for music that I downloaded from Youtube !. Had to use several programs and convert the video size, resolution, and format to be able to finally burn them in a DVD disk with a menu just like a movie DVD ! . FYI I was able to load 30 songs per Disk.
The only downside from using Youtube video clips is that the audio will be Stereo and not as crisp as compared to another DVD running high bit rate mp3 files only.
Old 07-22-20, 01:45 PM
Rossntwk
Rossntwk's Avatar
Originally Posted by whitebeast
Actually you could swapped the Mark Levinson unit to enable watching video. However, the CD playback is completely plug and play.
There are 2 thing you need to do for it fully functional.
1. You need to relocated 4 wires for the AUX
2. You would need custom wire for video signal
You don't need to have Mark Levinson Amp and 14 speakers for it to work. Your stock AMP working fine!!!!
HOPE IT HELP!!! I did swap 4 of them into None ML car so i know!!!
Thank you Whitbeast for this information!
So many people saying it cannot be done!
Can you please explain about:
1. Where to relocate 4 wires for AUX?
2. Custom wire for video feed from DVD head unit to video feed on back of GPS monitor?
Thank you so very much for your time and knowledge!
Old 12-04-20, 05:31 PM
gallery51
2nd gear
gallery51's Avatar
Originally Posted by NastyIS
Unless you hack it like many here have done. I hope this comment doesn't stir up the "that's too dangerous" comments.
I recently purchased a Lexus LS460 L fully loaded and I am able to watch movies but only when parked. How do I override that to watch anytime?
Old 12-06-20, 05:44 PM
eframsal
eframsal's Avatar
You’ll need 2 connectors along with 3 wires (preferably different colors) and 6 female pins that go into each of the connectors.
Part # for the connectors are 90980-12221 or 90980-12251 (it’s white in color and goes in the bottom middle socket behind the radio) and the other is 90980-12209 (it’s blue in color and plugs into the blue colored socket on the Nav unit.)
On connector 12221, red wire/pin goes in slot 1, green in slot 2, and black goes in slot 3. On connector 12209, red wire/pin goes in slot 1, green goes in slot 4, and black in slot 5. The connector will have the slots at each corner marked with a number.
Back of connector 12221
Back of connector 12209
nootha
Hybrid Technology
11-17-14 08:48 AM
buffguy
04-08-13 07:08 PM
Igor911
10-29-12 12:57 PM
Firstlps
01-15-07 04:22 AM
yov6cam
05-18-06 11:36 AM
Quick Reply: Lexus IS Can I use the CD changer to play movies?
