2008 IS250 Burning Oil-Part 2
Old 12-07-11, 10:18 AM
zinnerbug
zinnerbug's Avatar
Default 2008 IS250 Burning Oil-Part 2
So the saga continues as i have heard back from the dealership after the second and final run for an oil level check up.
Turns out that there is still oil burning in the engine, which now i am a alittle over a quart short after 2000 miles into my last oil change. According to the dealership, i was told that according to the owners Manual, it is COMPLETELY normal for the car to burn oil as long as it is not burning more than one quart of oil per 600 miles. if that is the case, then that would be grounds for either repairs and possible coverage in warranty. At this present time, the dealership does not have a case in order to proceed with the aftermarket warranty.
Anyway, has anyone heard of this crap? I have not looked through the manual since i have misplaced mine. Can anyone help with this?? please advise.
I am so over this crap, i am at a breaking point of trading in this puppy.
Eddie
Old 12-07-11, 10:54 AM
iRock
iRock's Avatar
Never heard of this. Sounds horrible.... I would get a new car. That's an insane amount of oil being burnt.
Old 12-07-11, 06:27 PM
grondie
Merkur Fanatic
grondie's Avatar
It does indeed state that in the owner’s manual, specifically; anything over 1.1qt per 600 miles is considered excessive and you should visit your Lexus dealer.. etc. Unfortunately, some engines just use more oil than others, which I’m sure is frustrating to no end, but it doesn't necessarily mean there’s anything wrong with it.
Old 12-07-11, 06:30 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,838 Likes on 2,327 Posts
Sounds like it didn't get broken in hard enough and the rings only marginally seated. My '93 Celica was that way. I've never followed factory instructions for break-in since.
Old 12-07-11, 06:44 PM
nosurprise
nosurprise's Avatar
well, the manual didn't exactly say it's normal, just that if the car consumes more 1.1qt per 600mi, you need to take it to the dealer. I won't consider that normal though, since that means you'll be out of oil before the next oil change.
Old 12-09-11, 02:45 PM
zinnerbug
zinnerbug's Avatar
I think i wil hold on to the car a few more months and deterimine how much consumption is actually taking place. In the event that it is consuming more than what should be allocated, i will go in and raise hell in hopes that they finally see that the engine is in need of repair. Keep your fingers crossed for me
Old 12-09-11, 04:41 PM
itruns
itruns's Avatar
I had a mustang GT 5.0 I bought brand new that burned 2-3 quarts between changes... Ran very strong until I got rid of it around 130k miles though.
Old 12-09-11, 05:13 PM
600rr05
600rr05's Avatar
dang never heard of this before... why not try and fix the problem with the dealership now instead of waiting a few months ? Ive had some issues in the past with my car regarding TSB which they told me drive it for a few months then if it happens bring it back needless to say either that rep is gone or magically there was no notes in the system....
Old 12-09-11, 06:19 PM
jbjones85
jbjones85's Avatar
that seems like a lot to me. My 350 (with almost 70K miles) stays at about the same level on the dipstick between changes.
Old 12-09-11, 08:13 PM
zinnerbug
zinnerbug's Avatar
ive tried to develop a case for the warranty company by doing oil checks the first 2000 miles. I was going every 1000 to determine how much oil consumption was taking place. Overall, i was losing about .75 quarts of oil every thousand miles. My adivisor was on my side and fought tooth and nail until the mechanic told her that it was nothing out of the ordinary since it clearly states in the owners manual that not enough consumption is taking place. Advisor basicaly told me that nothing can take place. So fustrated.
Should i get a second opinion? Read my other post on the "IS250 burning oil'?
Old 03-22-12, 10:19 PM
92fs
92fs's Avatar
I thought that I was the only one with a burning oil problem. I have a 2008 IS250 with 50k miles. I'm using Mobil 1 Full Synthetic 5W-30. I will check my oil level more frequently.
Old 03-23-12, 01:41 AM
JohnLX300
JohnLX300's Avatar
I have a 2008 IS250 w/ about 43k, no oil consumption at all.
Old 03-23-12, 02:04 AM
KillaIS250
KillaIS250's Avatar
Damn sorry to hear that, the oil level on my 07 IS250 barely moves between oil changes. It's definitely not near 1 qt after 2,000 miles. Hope you get everything sorted out!
Btw I noticed you mentioned you misplaced your manual. Lexus provides a free replacement manual, just fill out this form:
https://secure.lexus.com/lexus/auth-...RequestForm.do
I got mine pretty quick when I ordered it
Old 03-26-12, 08:32 PM
92fs
92fs's Avatar
I'm taking my 2008 IS250 to the dealer tomorrow, I will update with my findings.
Old 03-27-12, 03:57 AM
WhatYaGot
WhatYaGot's Avatar
I have 121,000 on my IS350 and the oil level stays the same between oil changes
Quick Reply: 2008 IS250 Burning Oil-Part 2
