Some punk punched in my roof
Whats the best option for self fix??
It basically looks like 10 knuckle sizes dents towards the rear of the roof. As if i was pelted by hail....but no paint damage.
?? please elaborate?
Should i attempt to buy one of those repair kits? The car is a lease, so i dont know if i want to invest in a body shop fix.
PS im super annoyed - ive had the car 10 months and have yet to park it between two cars. im the car in the corner spot parked diagonally, hence the haters punching in my roof
PDR = Paintless Dent Removal. You can usually find people that will come out to you and do the work. Charge you a flat rate per area usually to remove any dents.
And if parking diagonally in the corner spots is attracting haters, i would just park correctly in the corner spot to avoid future issues
Well you've answered your own question as to why this happened. Parking like that is probably the worst thing you can do to protect your car; it just screams out to people "Hey, I really, really would hate it if anyone did anything to my car", which of course then entices jerks to do just that. It's a car, and you're going to have to learn to get over a door nick here or there.
I take the corner spot and go 50% into the crosshatched area...or sometimes at an angle into the cross hatched area. Mother****ers in Miami don't give a ****. Not to mention my work lot is on sobe so lots of rental car and drunk drivers.
So should I buy one of those suction kits? Or would it be better to remove the headliner and have at it with a rubber mallet?
i would go that route if the dents were in more visible areas, in thicker, rigid sheet metal. but dings on the roof may be very easy to take out yourself, no? its one large, thin, flexible panel of sheetmetal.
does anyone know if those PDR suction devices actually work? i.e. something found in an auto parts store? thats the kind of suggestion im looking for....brand names and techniques.
I never get use to dents/scratches. I hate when people say it's just a car. I like my stuff to be spotless. How a person keeps and views their stuff says a lot IMO.
Having said that, I'm suprised you would want to attempt to remove the dents your self. If you park way out why would you cheap out on a a fix. I've heard the self removal kits don't work very well. Usually just a waste of time and money.
I've had paintless dent removal done for about $50 bucks on 2 small dents. Yet in Miami it's going to be more expensive.
Take this from a guy who does some sheet metal work. Lage flat panels are a ***** to work on. Listen to the advice of others on here and get some quotes for paintless dent removal. Some pics would really help, but it sounds like it shouldn't be to hard to fix for a pro.
The kits you can buy have their uses, but only in some areas and practice is essential to make sure you dont F*%@ stuff up.
Try Ding King first.... it's pretty much harmless if you follow the instructions.
https://www.dingking.tv/?leadsource=...FQwaQgodG2w5tA
Basically it's adhesive + sunction cup used to pull out the dings on your car.
I known people who used it for door dings and it worked wonders. But it also depends on the size of your ding. If it's on a relatively flat surface, then it will most like remove it.
