Valve cover gasket problem?
Old 08-27-11, 11:51 PM
NihS07
NihS07's Avatar
Default Valve cover gasket problem?
So I got my spark plugs changed today, but ran into a problem. The front driver's side spark plug had oil on it. So we tried draining most of the oil before pulling out the plug, the guy said it may be a bad valve cover gasket. Any ideas on what it could be and how much to fix. Thanks
Old 08-28-11, 07:06 AM
B16da9
B16da9's Avatar
easy pull the cover change the spark plug gasket looks like this "O" unless it's built into the main valve cover gasket like on some cars. Never the less I would change both the main gasket and the spark plug gasket while you have it taken apart.
I also recommend you do both sides and while you are at it change your spark plugs since you'll already be in there.
Old 08-28-11, 07:24 AM
Gville350
Gville350's Avatar
You need these :
11193 1119370010
GASKET, SPARK PLUG TUBE 03 In Stock $3.80 $3.16
11193A 1119370010
GASKET, SPARK PLUG TUBE, LH 03 In Stock $3.80 $3.16
http://is.sewellparts.com/oem-catalo...S250-2007.html
And since you'll already be in there, might as well do a new valve cover gasket too.
Old 08-28-11, 08:30 AM
NihS07
NihS07's Avatar
Thanks for all the help and quick responses, I'll order it today and try to fix it next weekend.
Old 08-28-11, 08:50 AM
Denver
Denver's Avatar
yes, change the spark plug o ring gasket and the valve cover gasket as well
Old 08-28-11, 11:02 AM
NihS07
NihS07's Avatar
Originally Posted by Gville350
You need these :
11193 1119370010
11193A 1119370010
Is this the correct part number for the valve cover gasket?
11213 1121331040
GASKET, CYLINDER HEAD COVER 01 In Stock $25.08
Old 08-29-11, 11:00 AM
Gville350
Gville350's Avatar
11214, since you said it was the drivers side bank.
Old 08-29-11, 09:59 PM
NihS07
NihS07's Avatar
should i just replace the driver's side since only that side is messed up or both sides?
Old 08-30-11, 06:52 AM
Denver
Denver's Avatar
if you want.. the other side will eventually leak
931UZFE
Performance & Maintenance
13
06-20-17 06:33 AM
eknine9
12-24-14 10:59 PM
02msmg3
12-16-10 10:50 AM
xdubber
01-14-10 02:53 PM
2muchpsi
12-01-07 07:47 PM
Quick Reply: Valve cover gasket problem?
