HELP! navi touch screen dont work :(
Old 08-25-11, 02:48 PM
DaNiELx626
DaNiELx626's Avatar
Default HELP! navi touch screen dont work :(
My 2006 IS250's screen stopped working. The whole unit still works, just the "touch" function doesn't work. I tried whipping off the stains on my navi last night with a drip of water and a microfiber tower. Could that possibly be the problem? My warranty expired. Any advice would be great
Old 08-25-11, 02:54 PM
uttam24
uttam24's Avatar
or it could be this
https://www.clublexus.com/forums/is-...e-nav-fix.html
pics: https://picasaweb.google.com/jacob.l...vscreenRepair#
Old 08-25-11, 08:01 PM
CCJ22
CCJ22's Avatar
a known issue. Search for the less then $50 cure
Old 08-25-11, 08:06 PM
edgeucated
edgeucated's Avatar
has it been confirmed that the $50 dollar cure is the culprit? or is that just one single documented case so far
Old 08-25-11, 09:28 PM
RAMAIR
RAMAIR's Avatar
Its official..... Cheap Ribbon, I have heard of 2 confirmed cases where the cheap ribbon connector was the problem...
If your going to do it F*** testing all the leads, just soldier all four connectors... Last thing you want is to rip your unit out again to fix same problem different lead in 6 months! JMO
Let us know how it goes... Good Luck
Old 08-25-11, 10:29 PM
bluby_U
bluby_U's Avatar
Whoever does it next please make
A video. They say the hardest part it taking out the vents. I don't wanna break ****t. I wanna do it asap. Mine has been out for 10 months
Old 08-25-11, 10:47 PM
edgeucated
edgeucated's Avatar
The vents really aren't that hard to take out. Just takes a little patience.
10 months?! I would have gone nuts by then. If your not good at soldering, I would just take it to a shop and have them do it. I do not think I can live with my navi being broken for 10 months. Every time I get into the car it would drive me nuts.
Old 08-25-11, 10:59 PM
whitebeast
whitebeast's Avatar
Then you should try it out or pay someone to do it for you. I mean 10 months without air conditioner is tough.
Old 08-25-11, 11:02 PM
DJKIBBLES
DJKIBBLES's Avatar
you can still use your ac. u just have to put it on auto and your the temp controller
Old 08-26-11, 12:17 AM
eggwoll
eggwoll's Avatar
It's something to do with the circuit connectors; I had the same issue two weeks agoand it was replaced under the lexus extended warranty. The cost for the new unit was around 1800
Old 10-27-11, 02:06 PM
CCJ22
CCJ22's Avatar
We just fixed vroomin350's NAVI using the less then $50 method. Well I just helped remove the NAVI out of the car but the procedure works flawlessly. Just ask vroomin350
Old 10-27-11, 06:11 PM
Coconut
Coconut's Avatar
I just fixed my touchscreen using that method and it worked. I resoldered all 4 traces on the ribbon cable. If your in the Bay Area, I could help you. PM if interested.
Old 10-27-11, 09:59 PM
Vroomin350
Vroomin350's Avatar
Jay you were more than a helping hand buddy,thanks again. and yes the $50 cure worked for me. Really it's more like a $20 cure, all you really need is a circuit writer pen, I bet my *** the culprit pins are always the same, 1 and 3.
And if ur slick return the pen for a full $20 refund make sure you keep your receipt
Old 10-28-11, 09:18 AM
Coconut
Coconut's Avatar
Hope your not serious because thats really shady and dishonest.
Old 11-03-11, 11:37 PM
Jleesd
Jleesd's Avatar
Anybody in the socal (SD, LA) area do this yet?? This just happened to me today. Touch constantly presses in one place (Left side) even when i touch other parts of the touch screen.
Quick Reply: HELP! navi touch screen dont work :(
